Enabling Siebel Server Component Groups for Safety System Integration
This task describes how to activate the component groups that are required for safety system integration.
This task is a step in Process of Setting Up Safety System Integration for Siebel Medical.
To enable Siebel Server component groups for safety system integration
  1. Navigate to the Administration - Server Configuration screen, and then the Component Groups view.
  2. Query for the Workflow Management Component Group.
  3. On the Component Groups applet, click the Enable button.
  4. Query for the EAI Component Group.
  5. On the Component Groups applet, click the Enable button.
  6. Restart the Siebel Server.
  7. Navigate to the Administration - Server Management screen, then the Servers and Component Groups view.
  8. Verify that the State value for the Workflow Management and EAI Component Groups is set to Online.
