Reviewing a Product Issue for Safety System Integration
You can review Siebel Medical product issue records with a status of Open for adverse event criteria.
This task is a step in Process of Setting Up Safety System Integration for Siebel Medical.
To review a product issue for safety system integration
  1. Navigate to the Product Issues screen, then the Product Issue view.
  2. In the Product Issue List, review the product issue for adverse event or product complaint criteria.
  3. (Optional) In the Reportable field, select Yes, No, or Potential.
  4. Click Review Complete.
    The product issue Status field updates to Review Complete.
