Sending Product Issue Follow-Up Information to the Safety System
You can update the submitted product issue record with follow-up information.
This task is a step in Process of Setting Up Safety System Integration for Siebel Medical.
To send product issue follow-up information to the safety system
Navigate to the Product Issues screen, then the Product Issue view.
In the Product Issue List, drill down on the record (in the PI# field) for which follow-up information must be sent.
Update the Product Issue record with the follow-up information.
In the Reportable field, select Follow Up.
Click Send to Safety.
