ActivateField Method for a Business Component |
Activates a field. |
Dim busComp as SiebelBusComp
BusComp.ActivateField(fieldName as String)
ActivateMultipleFields Method for a Business Component |
Activates multiple fields. |
busComp.ActivateMultipleFields(oPropSet as SiebelPropertySet)
Associate Method for a Business Component |
Creates a new many-to-many relationship for
the parent object through an association business component. |
busComp.Associate(whereIndicator as Integer)
BusObject Method for a Business Component |
Returns the name of the business object that
the business component references. |
Dim busObject as SiebelBusObject
Set busObject = busComp.BusObject
ClearToQuery Method for a Business Component |
Clears the current query but does not clear
sort specifications on a business component. |
busComp.ClearToQuery
DeactivateFields Method for a Business Component |
Deactivates the fields that are currently
active from the SQL query statement of a business component. |
busComp.DeactivateFields
DeleteRecord Method for a Business Component |
Removes the current record from a business
component. |
busComp.DeleteRecord
ExecuteQuery Method for a Business Component |
Returns a set of business component records. |
Dim buscomp as SiebelBusComp
buscomp.ExecuteQuery(cursorMode As Integer) As Boolean
ExecuteQuery2 Method for a Business Component |
Allows you to control the number of records Siebel CRM returns. |
buscomp.ExecuteQuery2(cursorMode As Integer,ignoreMaxCursorSize
FirstRecord Method for a Business Component |
Moves the record pointer to the first record
in a business component, making that record the current record. |
Dim bIsRecord as Boolean
bIsRecord
= busComp.FirstRecord
GetFieldValue Method for a Business Component |
Returns the value of a field from the current
record of a business component. |
Dim sValue as String
sValue
= busComp.GetFieldValue(FieldName as String)
GetFormattedFieldValue Method for a Business Component |
Returns a field value that is in the same
format that the Siebel client uses. |
sValue
= busComp.GetFormattedFieldValue
GetLastErrCode Method for a Business Component |
Returns the error code for the error that Siebel CRM logged most recently. |
Dim errCode As Integer
Dim SiebApp as SiebelDataControl
errCode=siebApp.GetLastErrCode
GetLastErrText Method for an Application |
Returns the text message for the error that Siebel CRM logged most recently. |
Dim sErr as String
sErr = busComp.GetLastErrText
GetMultipleFieldValues Method for a Business Component |
Returns a value for each field specified
in a property set. |
busComp.GetMultipleFieldValues(oFieldNames as SiebelPropertySet,
oFieldValues as SiebelPropertySet)
GetMVGBusComp Method for a Business Component |
Returns the multivalue group business component
that is associated a business component field. |
Dim mVGBusComp as SiebelBusComp
set mVGBusComp = busComp.GetMVGBusComp(FieldName as String)
GetNamedSearch Method for a Business Component |
Returns the name of a search specification. |
sValue
= busComp.GetNamedSearch(SearchName as String)
GetPicklistBusComp Method for a Business Component |
Returns the name of the pick business component
that is associated with a field in the current business component. |
Dim pickBusComp as SiebelBusComp
Set pickBusComp = busComp.GetPicklistBusComp(Field-Name as String)
GetSearchExpr Method for a Business Component |
Returns the current search expression that
is defined for a business component. |
Dim sExpr as String
sExpr =
busComp.GetSearchExpr
GetSearchSpec Method for a Business Component |
Returns the search specification that is
Dim sSpec as String
sSpec =
busComp.GetSearchSpec(FieldName as String)
GetUserProperty Method for a Business Component |
Returns the value of a user property. |
Dim retStr as String
retStr
= buscomp.GetUserProperty(prop As String) As String
GetViewMode Method for a Business Component |
Returns the visibility mode for a business
component. |
Dim iMode as Integer
iMode
= busComp.GetViewMode
InvokeMethod Method for a Business Component |
Calls a method. |
Dim sReturn as String
sReturn
= busComp.InvokeMethod(methodName as String, methArg1, methArg2, methArgN as String or StringArray)
LastRecord Method for a Business Component |
Moves the record pointer to the last record
in a business component. |
Dim bReturn as Boolean
bReturn
= busComp.LastRecord
Name Method for a Business Component |
Returns the name of a business component. |
Dim sName as String
sName =
busComp.Name
NewRecord Method for a Business Component |
Adds a new record to a business component. |
busComp.NewRecord(whereIndicator as Integer)
NextRecord Method for a Business Component |
Moves the record pointer to the next record
bReturn
= busComp.NextRecord
ParentBusComp Method for a Business Component |
Returns the name of a parent business component. |
Dim parentBusComp as SiebelBusComp
Set parentBusComp = busComp.ParentBusComp
Pick Method for a Business Component |
Places the currently chosen record in a pick
business component into the appropriate fields of the parent business
component. |
busComp.Pick
PreviousRecord Method for a Business Component |
Moves the record pointer to the previous
record in a business component, making that record the current record. |
bReturn
= busComp.PreviousRecord
RefineQuery Method for a Business Component |
Refines a query. |
busComp.RefineQuery
SetFieldValue Method for a Business Component |
Sets a new value in a field in the current
busComp.SetFieldValue(FieldName as String, FieldValue as String)
SetFormattedFieldValue Method for a Business Component |
record of a business component. It accepts the field value in the
current local format. |
busComp.SetFormattedFieldValue(FieldName as String, FieldValue as String)
SetMultipleFieldValues Method for a Business Component |
Sets new values in the fields of the current
busComp.SetMultipleFieldValues(oPropSet as SiebelPropertySet)
SetNamedSearch Method for a Business Component |
Sets a named search specification on a business
component. |
busComp.SetNameSearch(searchName as String, searchSpec as String)
SetSearchExpr Method for a Business Component |
Sets a search expression for a business component. |
busComp.SetSearchExpr(searchSpec as String)
SetSearchSpec Method for a Business Component |
Sets the search specification for a business
component. |
busComp.SetSearchSpec(FieldName as String, searchSpec as String)
SetSortSpec Method for a Business Component |
Sets the sort specification for a business
component. |
busComp.SetSortSpec(sortSpec as
String)
SetUserProperty Method for a Business Component |
Sets the value of a named user property. |
buscomp.SetUserProperty(property-Name as String, newValue as String)
SetViewMode Method for a Business Component |
Sets the visibility type for a business component. |
Dim boolVal as Boolean
boolVal
= buscomp.SetViewMode(mode As Integer)
UndoRecord Method for a Business Component |
Reverses any unsaved modifications made to
the record. |
busComp.UndoRecord
WriteRecord Method for a Business Component |
Saves to the Siebel database any modifications
made to the current record. |
busComp.WriteRecord
