FirstSelected Method for a Business Component
The FirstSelected method makes the first record of the multiple selection in a business component active. It also calls any associated events. It returns the same information as the FirstRecord method. For more information, see FirstRecord Method for a Business Component.
Format
BusComp.FirstSelected
No arguments are available.
Used With
COM Data Server, Server Script
Examples
The following examples use the FirstSelected method and the NextSelected method to allow you to customize multirecord deletion. If the user clicks a custom button in an applet, then Siebel CRM can call this code and it can call the Delete Selected custom method.
The following example is in Siebel eScript:
function BusComp_PreInvokeMethod (MethodName)
if (MethodName == "Delete Selected")
with (this)
var iRecord = FirstSelected();
while (iRecord)
DeleteRecord();
iRecord = NextSelected();
return (CancelOperation);
return (ContinueOperation);
}The following example is in Siebel VB:
Function BusComp_PreInvokeMethod (MethodName As String) As Integer
Dim iRtn As Integer
iRtn = ContinueOperation
If MethodName = "Delete Selected" Then
With me
Dim iRecord As Integer
iRecord = .FirstSelected
While iRecord
.DeleteRecord
iRecord = .NextSelected
Wend
End With
iRtn = CancelOperation
End If
BusComp_PreInvokeMethod = iRtn
End Function
