IsViewReadOnly Method for an Application
You can use the IsViewReadOnly method to determine if a view is read-only. This method returns the following information:
TRUE if the view is read-only
FALSE if the view is not read-only
If this method does not return TRUE or FALSE, then an error occurred. If this method does not return TRUE or FALSE, then your script must provide a handler.
Format
Application.InvokeMethod("IsViewReadOnly",viewName)
The following table describes the arguments for the IsViewReadOnly method.
| Argument | Description |
viewName |
The name of a view. You can include the name of this view in double quotes or in a variable that contains the name of the view. |
Usage
You can set a view as read-only for a particular responsibility in the Responsibility Administration view. You can use the IsViewReadOnly method to determine if a view is read-only for the current responsibility before you attempt to edit a field.
Siebel CRM does not automatically set a button to read-only when that button resides in a view that is read-only. You can use the IsViewReadOnly method to set a button to read-only in a view where IsViewReadOnly returns TRUE.
Used With
To use this method, you can use an Application.InvokeMethod call with the following interfaces:
Browser Script
COM Data Control
COM Data Server
Siebel Java Data Bean
Mobile Web Client Automation Server
Server Script
Examples
The following example for Siebel eScript determines if the active view is read only:
function ShowViewROStatus()
var sActive = TheApplication().ActiveViewName();
if (TheApplication().InvokeMethod("IsViewReadOnly",sActive) == "TRUE")
TheApplication().RaiseErrorText(sActive + "is read only.");
else
TheApplication().RaiseErrorText(sActive + "is not read only.");
