SetValue Method for a Control
The SetValue method sets the contents for a control. This method does not return any information.
Format
controlVar.SetValue (controlValue)
The following table describes the arguments for the SetValue method.
| Argument | Description |
controlValue |
String that contains the value that Siebel CRM must set for the control. |
Usage for the GetValue Method and the SetValue Method
Note the following usage for the SetValue method:
This method does not validate the format of the data. Data validation occurs when the user steps off the field or the record, or explicitly saves the record.
This method can set the value for a read-only control, but Siebel CRM does not save this information when the user saves the record.
The user can modify the contents of a control before Siebel CRM saves control information to the business component field.
Note the following usage for the GetValue method and the SetValue method:
These methods only work on form applets.
These methods work only for a control that references a business component field.
You cannot use these methods with a label.
Used With
Browser Script
Examples for the GetValue Method and the SetValue Method
The following code uses the GetValue method and the SetValue method:
function Applet_PreInvokeMethod (name, inputPropSet)
switch (name) {
// Example of changing the value of the Abstract control to uppercase
case ("SR Abstract"):
var ctlName = "Abstract";
var ctl = this.FindControl(ctlName);
var ctlVal = ctl.GetValue();
ctl.SetValue(ctlVal.toUpperCase());
ctl= null;
return("CancelOperation");
// Example of changing the value of a checkbox control
case ("SR Billable"):
var ctlName = "Billable Flag";
if (ctlVal == "Y")
ctl.SetValue("N"); // clear the box
else
ctl.SetValue("Y"); // check the box
ctl= null;
// Example of changing the value of a date/time control
case ("SR Commit time"):
var ctlName = "Agent Committed";
ctl.SetValue("12/1/2001 1:09:31 AM");
// format is not validated until user saves the record
ctl= null;
break;
