Environment Variables for Operating System Latches
This topic is part of Tuning the Siebel Server for All UNIX and Linux Operating Systems.
Depending on the total number of tasks on the Siebel Server, you might
need to set the environment variables described here in order to manage
these loads. SIEBEL_OSD_NLATCH controls named latches
and SIEBEL_OSD_LATCH controls unnamed latches. Latches,
which are similar to mutexes (mutual exclusion objects), are used for
communication between processes.
If SIEBEL_OSD_NLATCH and SIEBEL_OSD_LATCH
are not defined, the values are 5000 and 1000, respectively. If these
values are sufficient for the total number of tasks on the Siebel Server,
then you do not need to set these variables. Do not set these variables
to values lower than their default values.
stop_server command, then run
the cleansync utility.Set SIEBEL_OSD_NLATCH and SIEBEL_OSD_LATCH
on the Siebel Server computer based on the following formulas (define
the variables in the applicable profile for the Siebel Server):
SIEBEL_OSD_NLATCH= (7 times (cumulativeMaxTasksfor all components)) plus 1000SIEBEL_OSD_LATCH= 1.2 times (cumulativeMaxTasksfor all components)
Assume, for example, that you have enabled two multithreaded server components
on the same Siebel Server: SCCObjMgr_enu and WfProcMgr. For SCCObjMgr_enu,
MaxTasks = 700 and, for WfProcMgr, MaxTasks
= 150. In this example, the parameter values must be set as follows:
SIEBEL_OSD_NLATCH= 6950 = 7 times (700 plus 150) plus 1000SIEBEL_OSD_LATCH= 1020 = 1.2 times (700 plus 150)
SBL-OSD-00217: Error exceeded maximum number of latches
can sometimes be generated even when the variables are set according
to the recommended formulas.
