Tuning Kernel Settings for AIX
This topic is part of Tuning Siebel CRM for AIX.
There are several AIX kernel settings that you can tune for optimal
Siebel Server or Siebel Application Interface performance under AIX.
These include the Virtual Memory Management and TCP settings. You
must have root privileges to modify these settings. Use the vmo, ioo, and no commands
to tune the AIX kernel. For more information about AIX kernel settings,
including several that are not mentioned in this guide, see 1097858.1
(Article ID) on My Oracle Support. See also your operating system
vendor's documentation.
To change the kernel settings
Using a text editor such as
vi, open the/etc/rc.netfile for editing.Modify settings using
iooandno, following the guidance of 1097858.1 (Article ID) on My Oracle Support.Note: Use default values for settings forvmo.Save your changes and exit the editor.
Make sure that the rpc.statd and rpc.lockd daemons run on the Siebel Server computer and on the server computer where the Siebel File System is located. Then set the number of threads for the rpc.lockd daemon on each applicable server computer.
It is recommended to increase the number of rpc.lockd daemon threads from the default. If possible, use the maximum number of threads, which is 511. System degradation can occur and logins might be blocked if the rpc.lockd daemon is not configured to handle a large number of lock requests. For example, you might execute commands like this:
chssys -s rpc.lockd -a 511 stopsrc -s rpc.lockd; startsrc -s rpc.lockdRestart the server computer to have the new settings take effect.
