Adding a Summary Page to the Siebel Configurator User Interface
You can add a summary page that shows users how they have configured a product. This page displays the relationships from which the user has made selections along with attribute values. It also displays all the selected products the user has chosen with an editable quantity. If needed, you can make this quantity read-only by customizing the summary tab.
Each relationship is a hyperlink. When the user clicks on the relationship name, the selection page containing that relationship displays, and users can revise their selections.
The following figure shows an example of a summary page. The first portion of the page lists the relationships and the attribute values that have been selected. The last portion of the page shows the items that the user has selected from each relationship.
This task is a step in Process of Creating a Custom Siebel Product Configurator User Interface.
To add a summary page
- In the User Interface view, create a group, as described in Grouping Items onto Pages of the Siebel Product Configurator User Interface, and complete the fields with the values described in the following table. - Field - Value - Group Name - Enter the name that will be the tab or page title name. For example, enter Summary. - Group Theme - Select Summary Group Theme. - Sequence - Enter a number to set the sequence of the summary page. To make the summary page the last page in the series, enter a sequence number that is higher than the number of the other groups
- Do not add items to the group. The application generates the summary page automatically.
