Guidelines for Using the Grid Layout Group Theme
Observe the following guidelines when using the Grid Layout Group Theme:
- The Grid layout feature is not supported for multi-level grandchild control templates, which recursively includes the group theme to show a grid table inside of another grid table.
- The grid layout theme should be used judiciously. The performance of the Siebel Product Configurator UI degrades with the number of controls displayed within the page.
- The grid layout theme can be used to control the display of all types of controls in the interface, including controls based on fields, relationships, attributes, linked items and resources.
- The following UI Control templates can be used with the Grid layout Group Theme. - With the Web template JS (RELATIONSHIP): - Check Box GridLayout JS (eCfgControlCheckGridLayoutJS)
- Radio Buttons GridLayout JS (CfgControlRadioGridLayoutJS)
- Combo Box with Price Attribute Grid JS (eCfgControlComboAddPriceAttribGridJS) - With the Web template JS (ATTRIBUTES):
- Radio Button GridLayout for Attribute JS (eCfgAttributeRadioGridLayoutJS.)
 Note: If these templates are not available within the UI Control pick applet, then manually create a record in the pick applet and map it to the appropriate Web template files.
