Configuring Session Parameters for a Utility
This topic describes how to configure parameters that a utility requires to run a session.
To configure session parameters for a utility
Open a command line on the Siebel Server that uses Siebel Remote.
Navigate to the folder that includes the txnutl.exe file:
For a Siebel Server uses Windows, open a command window, and then navigate to the
SIEBEL_ROOT\siebsrvr\binfolder.For a Siebel Server that uses UNIX, navigate to the
SIEBEL_ROOT/binfolder.
Configure parameters for the session:
For a Siebel Server that uses Windows, you run siebenv.bat.
For a Siebel Server that uses UNIX, you do the following:
Run siebenv.sh or siebenv.csh, depending on the shell you are using.
To set the SIEBEL_REPOSITORY environment variable to Siebel Repository, run the setenv command.
