Expected Results from the Field Test of a Predefined Routing Model
The following table describes the results that you can expect from a successful field test.
| Expected Result | Description |
The size of the local database and the amount of data that Siebel Remote synchronizes decreases. |
These metrics must be smaller if you use a predefined routing model when compared to your previous routing model. |
The user can still do business tasks. |
Data must not be missing that prevents the user from completing a critical business process. |
Synchronization times decrease. |
The predefined routing model must result in a shorter synchronization time than the synchronization time that Siebel Remote experiences if you use the previous routing model. |
Siebel Remote routes every server transaction to the remote client except for those transactions that the routing models explicitly exclude. |
If Siebel Remote does not route every transaction, then the user responsibility might not match the routing model. |
Every view that accesses data on the Siebel Server displays the same data on the remote client. |
If every view that accesses data on the Siebel Server does not display the same data on the remote client, then there is a strong possibility that you included incorrect views in the user responsibility. |
