Values for System Preferences
The following table lists values for system preferences for Siebel Remote. You specify these values in the Remote System Preferences view of the Administration - Siebel Remote screen.
| System Preference | Default Value | Other Values |
Docking Timestamp Source |
Client Transaction Time |
Server Database Merge Time |
Enable Mobile Password Expiration |
Check box contains a check mark, by default. |
No check mark |
Enable Mobile Password Syntax Check |
No check mark |
Enable Mobile Web Client Lockout |
No check mark |
Enable Transaction Logging |
No check mark |
Expiration Period |
5 |
Positive integer greater than zero is a valid value. |
Failed Login Attempts |
2 |
Positive integer is a valid value. |
Intersection Table Conflict Resolution |
Merge |
You can use the following values:
Intersection Table Merge Rule |
First In |
Last In |
Lockout Period |
1 |
Merger Friendly Notification |
Conflicts |
Merger Transactions Commit |
50 |
Minimum Number of Characters |
5 |
Integers from 1 through 15 are valid. |
Optimized Visibility Check |
No check mark |
Password Content |
Alphanumeric Special Character |
SFM: Maximum File Attachment (KB) |
100 |
System Conflict Resolution |
Server Wins |
Client Wins |
Visibility Rules Per Statement |
50 |
Not applicable. |
Visibility Rules Per Statement 1 |
20 |
Not applicable. |
Visibility Rules Per Statement N |
1 |
Not applicable. |
Warning Period |
2 |
