Remote Configuration Option for Developer Web Client
This option applies only to the Siebel Developer Web Client. The remote configuration option can be implemented in the following authentication strategies:
Security adapter authentication: LDAP, custom (not database authentication)
Web SSO authentication
With this approach, you create a separate text file that defines any parameter values that
   configure a security adapter. You configure all security adapter parameters, such as those in a
   section like [LDAPSecAdpt], in the remote file, not in the application
   configuration file.
Storing configuration parameters in a centralized location can help you reduce administration overhead. All Developer Web Clients can read the authentication-related parameters stored in the same file at a centralized remote location.
The following examples show how a remote configuration file can be used to provide parameters for a security adapter that is implemented by Siebel eService in a Web SSO environment. The following example is from the configuration file uagent.cfg for Siebel Call Center:
[InfraSecMgr]
SecAdptMode = LDAP
SecAdptName = LDAPSecAdpt
UseRemoteConfig = \\it_3\vol_1\private\ldap_remote.cfg
In this case, the configuration file ldap_remote.cfg would contain an
    [LDAPSecAdpt] section. It could be defined similarly to the example earlier in
   this topic, and would contain no other content. The application configuration file would contain
   the [InfraSecMgr] section as defined in the preceding example. It would not
   contain an [LDAPSecAdpt] section and, even if it did, it would be ignored.
To implement remote security configuration for Siebel Developer Web Clients, follow these guidelines:
The
[InfraSecMgr]section in the Siebel configuration file must include theUseRemoteConfigparameter, which provides the path to a remote configuration file. The path is specified in universal naming convention format, for example,\\server\vol\path\ldap_remote.cfg.The remote security configuration file contains only a section for configuring the security adapter, such as the
[LDAPSecAdpt]section.Each Developer Web Client user must have read privileges on the remote configuration file and the disk directory where it resides.
