Applying the Additive Changes in One Job
You can apply all the additive schema upgrade changes to the target
database using the JCL in the data set DSNHLQ.SIEBEL.INSTALL.JCL(ADDVSCHT) provided you also applied
all of the additive changes to the staging database using the JCL
in the DSNHLQ.SIEBEL.INSTALL.JCL(ADDVSCHS) data set.
DSNHLQ.SIEBEL.INSTALL.JCL(ADDVSCHS). If you do, you will corrupt the target database.To apply all additive changes to the target production database
- Navigate to the ISPF Primary Option Menu, and select option 2: Edit.
- Specify - DSNHLQ.SIEBEL.INSTALL.JCL(ADDVSCHT)as the name of the data set member you want to edit on the Edit Entry Panel.
- Submit the job in the - ADDVSCHTmember.- All of the additive schema changes are automatically submitted and applied to the target database. Note: You must choose to either apply all of the additive changes in one job, or apply them all individually. If you apply any of the additive changes to the target database individually, as described in Applying Additive Changes Individually, you cannot use the- DSNHLQ.SIEBEL.INSTALL.JCL(ADDVSCHT)member to apply additive changes; attempting to do will cause an error in your upgrade.
- To ensure performance is not adversely affected when additive changes are applied in one job using the - ADDVSCHTmember, all of the indexes are created using the DEFINE YES, DEFER YES syntax. After applying the additive changes, you can rebuild the indexes for each index created by the- ADDVSCHTmember by submitting the JCL in the- DSNHLQ.SIEBEL.INSTALL.JCL(SUBADDIX)data set.- You can submit the index rebuild jobs all together, or individually. To submit the rebuild index jobs in one step: - Navigate to the ISPF Primary Option Menu, and select option 3.4.
- On the Data Set List Utility (DSLIST) panel, type - EXECon the line next to the @SUBADDIX member. Press Enter.- All of the rebuild index jobs are submitted.
 - To submit each index rebuild job individually: - Edit the - DSNHLQ.SIEBEL.INSTALL.JCL(SUBADDIX)member by typing- ebefore the member name. Press Enter.
- Select the job you want to run, type - submiton the command line, and press Enter.- The rebuild index job is submitted.
