Before You Begin
Before starting the incremental upgrade process, you must have installed the Siebel Enterprise Server, which includes the Siebel Gateway Name Server, the Siebel Server, and the Siebel Database Server. For installation information, seeSiebel Installation Guide for the operating system you are using.
This task is a step in Process of Performing Incremental Upgrade of Siebel Database from Siebel CRM 8.1.1.x.
Note: Before running incremental repository merge, you must have one and only
one repository in your development instance and that repository must
be named Siebel Repository. Also, if you must delete any additional repositories,
the only acceptable way to do so is to select the repository record in
Siebel Tools and delete it. It is not acceptable to delete repositories
using direct SQL.
