Database Configuration in Siebel Enterprise Server Installer
In the Siebel Enterprise Server installer for your monthly update release, users (including administrator users) must review and modify the database details when prompted by the installer. The following database configuration in Siebel Enterprise Server installer is required:
Select the Edit Configuration check box on the DB Config Utility Screen of the installer to modify the database parameters.
The following table describes the parameters that apply for all databases:
Field
Description
Example
RDBMS
Database Platform Name
Oracle Database Enterprise Edition
Microsoft SQL Server
IBM DB2 UDB for Linux UNIX Windows
IBM DB2 for z/OS
Database Table Owner
Table Owner
SIEBEL
Database Table Owner User
Table Owner User
SIEBEL
Database Table Owner Password
Database Username
Database Username
SADMIN
Database Password
Database Password
ODBC DataSource Name
Siebel_DSN
Repository Name
Siebel Repository Name
Siebel Repository
Security Group Id/Grantee
SSE_ROLE
UNICODEDB
Y for Unicode DB, N for non-Unicode DB
Y
PRIMARY_LANG_CD
Primary language
English
OTHER_LANG_CD
Other languages. If you have more languages in your database, highlight them here.
German
Japanese
Hebrew
The following table describes the parameters that apply for Oracle and DB2 UDB databases:
Field
Description
Example
Index Tablespace Name
The default Indexspace
INDSPC, SEBL_IDX
Tablespace Name
The default Tablespace
TBLSPC, SEBL_TBL
The following table describes the parameters that apply for IBM DB2 UDB for Linux, UNIX, and Windows:
Field
Description
Example
Tablespace 16K
16K Page Tablespace
TBLSPC16K
Tablespace 32K
32K Page Tablespace
TBLSPC32K
The following table describes the parameters that apply for DB2390 databases:
Field
Description
Example
4KBUFFERPOOL
4K Buffer Pool (Required).
BP1
8KBUFFERPOOL
8K Buffer Pool (Required).
BP8K1
16K BUFFERPOOL
16K Buffer Pool (Required).
BP16K1
32KBUFFERPOOL
32K Buffer Pool (Required).
BP32K1
DBNAMEPREFIX
Database Name Prefix (Required).
D + Last 3 Characters of your schema qualifier
DBCODE
Database Code Page (Required).
ASCII/EBCDIC/UNICODE
INDEXBUFFERPOOL
Index Buffer Pool (Required).
BP2
STOGROUPINDEXES
Storage Group for Indexes (Required).
SYSDEFLT
STOGROUPTABLES
Storage Group for Tables (Required).
SYSDEFLT
When prompted by the installer, enter the database password which is not stored in any configured files.
When installation of the update release completes, the installer calls the PostInstallDBSetup utility and updates the status returned. That is, the installer displays whether the PostInstallDBSetup utility ran successfully or failed.
The PostInstallDBSetup utility executes the required seed, schema, and manifest changes to the Siebel database. If there are failures with Post Installation Database Update, then re-execute the PostInstallDBSetup utility in standalone mode, after fixing any errors. For more information, see Rerunning Post Installation Database Update.
After the PostInstallDBSetup utility has completed running, a Post Installation Database Update Report is automatically generated.
