Deploy to Users
  1. Upgrade your Siebel Mobile Web and Developer Web Clients. See Siebel Installation Guide for further information.
  2. If you have customized the configuration of Siebel Enterprise Server components, such as Siebel Servers, you must manually enter the customizations in the upgraded environments. For information on this task, see Siebel System Administration Guide.
  3. Use Siebel Anywhere to create distribution kits for deployment. See Siebel Anywhere Administration Guide.
  4. Generate a Siebel Remote database template. See Siebel Remote and Replication Manager Administration Guide.
  5. Set up database extraction for Siebel Mobile Web Clients. See Siebel Remote and Replication Manager Administration Guide.
