Determining Which Template File Was Used During an Extract or Merge
Upgrades: All upgrades.
Environments: Development environment only.
This topic describes how to determine which template file was used for an extract or merge operation when a storage control file is created.
This topic is part of an upgrade process. See Performing a Siebel Database Upgrade.
To determine the template file that was used for an extract or merge operation
Open the dbextract.log file and review the command line that was entered.
Check the value for the /i parameter. You can also check the upgwiz.log file for the
strgupgd.exe
command string./i D:\18025\dbsrvr\db2390\storage_p_u.ctl
UpgradeLogUpgradeInfo30000000254290624:0 2014-09-29 12:06:59 Executing (C:\81_23039QF3_390CV\ses\siebsrvr\bin\strgupgd.exe /s C:\81_23039QF3_390CV\ses\dbsrvr\db2390\storage_p_u.ctl /d C:\81_23039QF3_390CV\ses\dbsrvr\db2390\SStempstore.txt /i C:\81_23039QF3_390CV\ses\dbsrvr\db2390\strgvar.inp /m C:\81_23039QF3_390CV\ses\siebsrvr\bin\master_dbconfig_extract_merge_mf.ucf)
