Example of a Siebel Development Environment Upgrade Flow
This topic presents the flow of steps in part of a typical development environment upgrade. The steps are extracted from an actual driver file. To perform an upgrade, the Upgrade Wizard reads the steps in a driver file and performs the commands the steps contain. The driver file type used in this example is as follows:
    Upgrade: Siebel 15.0 to Siebel 17.0
    Environment: Development
    Upgrade mode: upgrep
    Multilingual: No
Upgrading the Siebel Database Schema (upgrep) is a two-step process, where you select each of the following upgrade processes in turn:
    zSeries Staging of Files for Upgrade: master_upgrep_dev_150_mf_m.ucf
    zSeries Seed/Repository Upgrade: master_upgrep_dev_150_mf.ucf
Example Steps in a Development Environment Upgrep Staging of Files
The following table shows the steps in the driver file for zSeries Staging of Files for Upgrade.
| Step | Script or Input File | Description |
| 1. Generate the DDL file for the staging database. | strgupgd | Generates the DDL file for the staging database. |
| 2. Copy files into the output directory. | strgupgd | Runs the extract and merge process to create the storage control file. The database administrator must perform operations using the files in the $GenDDLDirectory directory. Once the operations are completed, resume the Upgrade Wizard operations by submitting the
         following command line on the midtier computer:
| 3. Restart the midtier file generation process. | strgupgd | Restarts the midtier file generation process for the upgrade. If all necessary mainframe tasks completed successfully, click YES to continue, otherwise click NO to terminate this process. If you choose NO, you can resume Upgrade Wizard operations by submitting the following
         command line on the midtier computer:  |
| 4. Generate the DDL for the additive schema changes. | Ddlimp2 | For the DB2390 staging database, run the ddlimp file to generate the schema.additive.sql file. |
| 5. Copy files into the output directory. | strgupgd | Generates a set of files in the $GenDDLDirectory directory. The database administrator must transfer these files from the $GenDDLDirectory directory to the mainframe using the ftp_pause1.txt and perform all required tasks on the DB2 host commands. Once completed, you can resume Upgrade Wizard operations by submitting the following
| 6. Restart the midtier file generation process. | strgupgd | Restarts the midtier file generation process for the upgrade. If all necessary mainframe tasks completed successfully, click YES to continue, otherwise click NO to terminate this process. If you choose NO, you can resume Upgrade Wizard operations by submitting the following
| 7. Generate the DDL for temporary tables. | ddlimp | Creates the temporary tables for the z/OS upgrade. |
| 8. Generate the DDL for Siebel tables. | ddlimp | Creates the schema for the z/OS upgrade. |
| 9. Copy files into the output directory. | strgupgd | Generates a set of files in the $GenDDLDirectory directory. The database administrator must transfer these files from the $GenDDLDirectory directory to the mainframe using the ftp_pause2.txt and perform all required tasks on the DB2 host commands. Once completed, you can resume Upgrade Wizard operations by submitting the following command line on the midtier computer: $GenDDLDirectory\upg_restart |
| 10. Restart the midtier file generation process. | strgupgd | Restarts the midtier file generation process for the upgrade. If all necessary mainframe tasks completed successfully, click YES to continue, otherwise click NO to terminate this process. If you choose NO, you can resume Upgrade Wizard operations by submitting the following
| 11. Generate the DDL for Siebel indexes. | ddlimp | Creates the indexes for DB390 development upgrade. |
| 12. Copy files into the output directory. | strgupgd | Generates a set of files in the $GenDDLDirectory directory. The database administrator must transfer these files from the $GenDDLDirectory directory to the mainframe using the ftp_pause3.txt and perform all required tasks on the DB2 host commands. |
Example Steps in a Development Environment Upgrep Seed Repository
The following table shows the steps in the driver file. The Script or Input File column in the table lists the SQL file or input file that is executed in each step. The Comment column provides a brief explanation of what the SQL file or input file does.
| Step | Script or Input File | Comment |
| Verify repository name | rename_existing_repositories.sql | Renames Siebel Repository to Prior Customer Repository. |
| Preparation of prior customer repository | SWTClob.jar RepCrawler.jar | The SWT to OD Conversion Utility converts Siebel Web Templates to an Object Definition Layout. Converted Web templates are stored in the database. The Repository Sanitization Utility searches the entire repository for unreferenced repository objects. Unreferenced repository objects are deactivated if they are not used by any application. |
| Import Siebel seed data | dataimp utility seedupg0.inp as input seedupg1.inp as input seedupg_locale.inp as input | Prior to importing seed data, dataimp deletes existing seed data. The seedupg* files contain filters that dataimp uses to prevent deleting seed data that you have modified or seed data meeting specified criteria. Unmodified seed data has a last update date (LAST_UPD) of 1980-01-01. Dataimp does not delete records where LAST_UPD is later than this date. |
| Upgrade data after seed data import | upg_data_afterseed.sql | For customers who have not converted to UTC time, sets the UTC value in S_SYS_PREF to False. For customers who have converted to UTC time, the script takes no action. |
| Upgrade data after seed data import SIA | upg_data_afterseed_sia.sql | None. |
| Set system preference for codepage for DB | set_codepage.sql | Sets the database codepage in the S_SYS_PREF. |
| Update version component information | upd_upgcomp.sql | Updates the S_UPG_COMP table with the product release level. The S_UPG_COMP table stores version information for application executable programs. |
| Encryption Upgrade | EncryptionUpgrade.jar | Siebel Business Applications allow customers to encrypt sensitive information stored in the Siebel database, for example, credit card numbers, Social Security numbers, birth dates. This information cannot be viewed without access to Siebel Business Applications. Sensitive data can be encrypted by using AES (Advanced Encryption Standard). This utility identifies the RC2 encrypted columns and upgrades their data to the AES. This utility updates the logical layer of data for columns which are candidates for encryption. |
| Export prior customer repository | repimexp utility | Exports the existing prior customer repository to create the new customer repository. |
| Import Prior Siebel, New Siebel, and New Customer repositories | repimexp utility | Imports the prior Siebel repository, new Siebel repository, and the new customer repository in parallel to the repository tables. |
| Install SQL packages | seeduver.sql | Verifies that versions are set correctly in S_APP_VER. |
| Install SQL packages | ifstrg.sql | Sets storage parameters for Siebel Enterprise Integration Manager tables. |
| Install SQL packages | ifindxstrg.sql | Sets storage parameters for Siebel Enterprise Integration Manager table indexes. |
| Install SQL packages | pkgseq.sql | Adds a suffix to row IDs in the S_SEQUENCE table. Ensures that row IDs are unique. |
| Install SQL packages | pkgldel.sql | Defines s_txn_log_del_proc. Procedure periodically deletes transactions from S_DOCK_TXN_LOG. Also deletes rows from S_DOCK_TXN SET. Prevents need for large rollback segment. |
| Install SQL packages | trgreset.sql | Ensures that denormalized rows in S_TERR have correct values. |
| Install SQL packages | ddlseq.sql | Sets sequence numbers for specified tables. |
| Install SQL packages | pkgvis.sql | Creates function that modifies how Oracle optimizer does visibility check. |
| Fix column alignment for custom objects | AlignApplet.jar | Applet alignments are executed based on the data type of the field. Alignments, which can be one of the following, are executed across the entire Repository for a similar look and feel of fields:
| Create temporary indexes for merge performance | crt_temp_indexes_merge.sql | Creates temporary indexes to improve the merge performance. |
| Take backup of DB and update DB stats | None | Pauses the Siebel Upgrade Wizard to enable a database backup and the execution of database statistics before the merge. |
| Execute Incremental Repository Merge | siebdev | Starts the incremental repository merge automatically for Windows. If you are using a Windows computer and Siebel Tools is installed for Siebel Enterprise servers in UNIX environment, then you must perform this step manually. |
| Generate Merge Report | MergeReport.jar | Generates the hierarchical merge report in HTML format. Also creates the file
         IRM_Merge*_ERROR.txt in   |
| Export merge data to CSV | ExportMrgCSV.jar | Exports repository-merge log data to a CSV file for business object, business component, applet, view, and Web page object definitions. This data can be compared with the Usage Pattern Tracking (UPT) CSV files to obtain the intersection data, so that you can focus testing on these objects only. The Siebel Upgrade Wizard exports the log data to CSV files in the following folder:
| Record Upgrade History | store_history.sql | Stores the upgrade history in the S_INST_UPG_HIST table. |
Steps That the upgphys Process Executes
The following table shows the different steps executed by the upgphys process. The Script or Input File column in the table lists the SQL file or input file that is executed in each step. The Description column provides a brief explanation of what the SQL file or input file does.
| 1. Check whether the merge and conflict resolution steps are complete | verify_irm.sql | Verifies whether the merge and conflict resolution steps are complete. |
| 2. Drop temporary indexes created for merge performance | drop_temp_indexes_merge.sql | Removes all the temporary indexes created to improve the merge performance. |
| 3. Export schema definition | None | Exports the schema definition to the file
| 4. Generate files to synchronize the physical and logical schema | schema.ddl | Applies the schema.ddl and synchronizes the tables and indexes. |
| 5. Migrate query search controls of list applets into the Siebel database | SrchCntrlMigration.jar | This step migrates query search controls of list applets from files into the Siebel database. This step also exports the entire New Customer Repository to:
| 6. Enable Workspace | EnableWorkspace.exe | Enables the Workspace on the New Customer Repository for repository content. |
| 7. Encryption Upgrade - Physical | EncryptionUpgrade.jar | This step updates the physical layer data for columns which are encrypted with the RC2 algorithm. This updates the data to AES algorithm. |
| 8. Export repository to a file | None | Exports the New Customer Repository
          to: This step exports the Design Time Repository (DR) to the custrep_dev.dat file and Runtime Repository (RR) to the custrep.dat file. The custrep.dat file contains only the required repository data and is used as an input to the production test and production environments. |
| 9. Import New Customer Repository as Siebel Repository | custrep_dev.dat | Truncates the repository tables and imports the previously exported New Customer Repository as Siebel Repository. This step imports the Design Time Repository (DR) from the custrep_dev.dat file. |
| 10. Enable Workspace for Seed data | EnableWorkspace.exe | Enables the Workspace on the New Customer Repository for Seed data (List of Values). |
| 11. Copy files to the output directory. | None | Copies files to the output directory. |
| 12. Verify repository after upgrade | dbchck dictutl mlovupgd SeedConflict.jar | The repository is optionally verified after you complete the upgphys process. This step is executed if you selected the option Verify Repository After Upgrade in the Database Configuration Wizard. |
| 13. Upgrade history | store_history.sql | Stores the upgrade history in the S_INST_UPG_HIST table. |
