Exporting with the Migration Schema Service
You can export a Migration Schema resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to export a resource:
- URI: - http://<host>:<port>/siebel/v1.0/service/Migration Schema Service/Export
- HTTP Method: POST
- Content-Type: application/json
- Authorization: Basic
- Request parameter: - migrationid: Use the migrationid parameter to include the migration identification value in the REST API request.
- Request body: - { "body":{ "migrationid": "<Migration Id value> } }
The following are the details for the response to a successful request:
- HTTP Code: 200
- Response parameters: - trackingid: String that contains the tracking identification value.
- Response body: - { "trackingid": "<tracking ID value>" }
