How to Locate Siebel Migration Resource Log Files
Siebel Migration resource files are stored in the following location:
Windows: SIEBEL_FILESYSTEM/migration/<migration id>
where:
    SIEBEL_FILESYSTEM: Indicates the location of the Siebel file system. -
      migration:Indicates the location of all the Siebel Migration files.
      inp:Indicates the input file.
      rul:Indicates the rule file.
      <migration id>:The ID generated by the Siebel Migration Application when the user executes the migration plan.-
         inp: Contains a copy of the input file used for a migration execution.
         rul: Contains a copy of the rule file used for a migration execution.
         dat: Contains all the data files generated by the export or moved from the source to target for import.
         log: Contains the log file generated by the export or import.
         schema: Contains the schema file generated schema export or moved from source for import.
         other: Contains the Web artifacts or file system artifacts for export and moved from the source for import.
