Postupgrade Tasks for Siebel Application Configuration
  1. Perform the tasks in the following to prepare for system testing:
  2. Verify the function of interfaces in integrated applications.
  3. Deploy workflows. To perform these tasks, see Siebel Business Process Framework: Workflow Guide.
  4. If you have set up integrations for transferring data to or from third-party applications using Siebel EAI, verify the integrations are configured correctly. For information on using EAI, see Overview: Siebel Enterprise Application Integration.
  5. If you have used EIM to set up batch processing jobs, verify EIM is configured correctly. For information on using EIM, see Siebel Enterprise Integration Manager Administration Guide.
  6. If you customized style sheet or Web template files in the previous release, implement those customizations in the new release again and execute a Full Publish operation to compile the Siebel Runtime Repository data.
    Carefully review the UI in the new release before implementing customizations to those files.
