Preupgrade Tasks for the Siebel Database
Review guidelines for configuring DB2 for z/OS. See Implementing Siebel Business Applications on DB2 for z/OS.
Verify that the Workflow Monitor and Workflow action agents have processed all pending requests.
Stop the Siebel Servers.
7.5.3 upgrades only: Perform the task in Updating Table Space Group Names.
Remove customized database triggers.
The Siebel upgrade process is not designed to support custom database triggers. If you have created customized triggers for the Siebel schema to be upgraded, you must remove them before starting the Siebel upgrade process. You can re-create these objects once the Siebel upgrade completes successfully.
Prepare the storage control file to use in the upgrade. See Process of Preparing the Storage Layout of the Schema.
Perform the tasks in the following:
The chapter in Siebel Database Upgrade Guide that describes basic database preparations for a Siebel upgrade.
