Regenerating the Siebel Repository Definition Files
Upgrades: All upgrades.
Environments: Development environment only.
Platforms: All platforms.
This topic is part of an upgrade process. See Performing a Siebel Database Upgrade.
If you have modified repository objects after the development environment upgrade (upgphys) and before upgrading the production test environment, you must regenerate the schema.ddl and custrep.dat files. These files were created during the upgphys process:
  • Schema.ddl. This file contains the logical definition of the Siebel database.
  • Custrep.dat. This file contains the definition of repository objects.
These files are used as input to the production test and production environment upgrades. These files contain only the Runtime Repository and required Design Time Repository which is required for production environments. There is an additional custrep_dev.dat that contains the entire development repository. This can be created for backup. If you modify the object definitions or the schema definitions in the repository after these files have been created, you must regenerate the files.
