Restarting Upgrade Jobs That Fail
Upgrades: All upgrades.
Environments: All environments
This topic is part of an upgrade process. See Performing a Siebel Database Upgrade.
This topic describes how to restart mainframe upgrade jobs that fail.
To restart a mainframe upgrade job that fails
Identify the job that failed under the SDSF exit (job status).
You can find the name of the job that failed using one of the following options on the In-Place Upgrade Main Menu:
Option 5: Staging Database Joblog
Option 6: Target Database Joblog
See Running SQL in Siebel Logs for further information.
Determine the reason the job failed. You can determine the reason for the job failure by selecting the job on the SDSF output queue panel using the
saction character.Correct the problem.
If a job fails because of an SQL error, fix the problem in the appropriate SQL PDS member. For example, for PRESCHM jobs, you can locate the relevant SQL PDS member in the
DSNHLQ.SIEBEL.PRESCHM.SQLdata set.Note: If you require help in performing these tasks or if you require confirmation that the tasks that you are about to run are correct, create a service request (SR) on My Oracle Support. You can log service requests by accessing My Oracle Support (Service Request tab), or by using your existing phone support numbers to contact Oracle Global Customer Support.Once the problem has been identified and corrected, restart the job. You can do this by selecting the job that failed on the SDSF output queue using the
SJaction character. This will automatically call up the next scheduled job allowing the upgrade process, for example PRESCHM, to continue.
