Roadmap for Upgrading from Siebel 7.x, 8.0.x or 8.1.1.x Without a Development Environment
If you are upgrading from Siebel CRM Release 7.x, 8.0.x or 8.1.1.x, and you do not have a development environment, complete the processes in this roadmap in the order shown.
Upgrading without a development environment means the following are true:
  • You are running an uncustomized, preconfigured version of Siebel Business Applications.
  • You have not used Siebel Tools to create or modify any objects or logical schema definitions in the Siebel Repository.
  • You have not modified the physical schema in the Siebel database.
If your upgrade meets these criteria, complete the following processes in the order shown:
  1. Process of Planning a Siebel Database Upgrade.
  2. Preparing for a Siebel Upgrade Without a Development Environment.
  3. Perform a production test upgrade. See Process of Upgrading a Production Test Environment.
  4. Process of Tuning the Upgrade Performance.
  5. Upgrade your production environment. See Process of Upgrading a Siebel Production Environment.
