Starting the Siebel Upgrade Wizard
Use this procedure to start the Upgrade Wizard. See Restarting the Siebel Upgrade Wizard After Pauses for the procedure to restart the Upgrade Wizard after it has paused and Stopping the Siebel Upgrade Wizard for the procedure to stop the Upgrade Wizard.
To start the Upgrade Wizard
Navigate to the following directory:
Windows:
SIEBEL_ROOT\binUNIX:
$SIEBEL_ROOT/bin
Enter the following command from the command line:
Windows:
siebupg /m master_UPGRADEOPTION_ENVIRONMENT_VERSION_MasterFileType.ucfUNIX:
srvrupgwiz /m master_UPGRADEOPTION_ENVIRONMENT_VERSION_MasterFileType.ucfwhere
UPGRADEOPTION_ENVIRONMENT_VERSION_MasterFileTypeis the portion of the upgrade configuration filename that lists the upgrade process, the upgrade environment, the Siebel release from which you are upgrading, and the type of mf_ file. The file is located inSIEBEL_ROOT\bin(UNIX:$SIEBEL_ROOT/bin). See About the Siebel Database Configuration Utilities and Database Configuration Wizard for further information.Note: Specify eithermf_mormffor the MasterFileType value depending on whether you want to start the manual or automatic portion of an Upgrade Wizard process.The following table lists examples of filenames for an upgrade from Siebel CRM version 8.1.1
Upgrade Option
Master_ File Generated
Development environment upgrep
master_upgrep_dev_811_mf_m.ucf
master_upgrep_dev_811_mf.ucf
Development environment upgphys
master_upgphys_dev_811_mf.ucf
Production environment upgrep and upgphys
master_upgrep_prod_811_mf_m.ucf
master_upgrep_prod_811_mf.ucf
To begin the upgrade, click OK (Windows) or click Enter (UNIX).
The Upgrade Wizard resumes from the point at which it stopped.
