Tables Amended During PRET Unload Processing
The unload job control cards for specific tables have been modified so that during PRET (pre-table) processing, the data in the tables is modified during the table unload process instead of being modified after the data has been loaded into the target table.
The following table lists the tables containing the data that is modified during unload processing, the macro that performs the modifications, and the relevant upgrade paths.
PRET Tables Modified During the Table Unload Process | Macro | Siebel Business Applications Paths | Siebel Industry Applications Paths |
S_APPL_WEB_TMPL |
PTH0062 |
Not applicable |
SIA753 |
S_APPL_WTMPL_IT |
PTH0064 |
Not applicable |
SIA753 |
S_CONTROL |
PTH0222 |
All Paths |
All Paths |
S_PCONTROL |
PTS0223 |
HOR753, HOR77 |
SIA753 |
S_FN_CRDT_RPT |
PTS0224 |
HOR753, HOR77 |
SIA753 |
S_ASGN_RULE_GRP |
PTS0225 |
HOR753, HOR77 |
SIA753 |
S_REGION |
PTS0227 |
Not applicable |
SIA753 |
S_REGION |
PTS0228 |
Not applicable |
SIA753 |
S_QTA_OBJCRT_D |
PTH0833 |
All Paths |
All Paths |
S_ETL_TIME_DAY |
PTS0313 |
Not applicable |
SIA753 |
S_ETL_TIME_DAY |
PTS0314 |
Not applicable |
SIA753 |
S_EXTDATA_TBL |
PTS0500 |
Not applicable |
SIA753 |
S_PAPL_WEB_TMPL |
PTS0505 |
Not applicable |
SIA753 |
S_NOTE_CON |
PTM0520 |
Not applicable |
SIA77 |
S_NOTE_PROD_INT |
PTM0520 |
Not applicable |
SIA77 |
S_NOTE_ACCNT |
PTM0520 |
Not applicable |
SIA77 |
S_DOCK_TXN_LOG |
PTM0010 |
All Paths |
All Paths |
S_ESCL_REQ |
PTM0010 |
All Paths |
All Paths |
DSNHLQ.SIEBEL.EXEC
or in the VSTG0300 and the VSTG0310 staging data sets.
