Upgrade Siebel Database Schema (upgrep)
(Optional) Change the Siebel Database Configuration Wizard language. For information on this topic, see the chapter in Siebel Database Upgrade Guide that describes how to upgrade the Siebel database.
Create the staging database by performing the following tasks:
Generate the Upgrade Files by performing the following tasks:
Note: Edit the generated files as required by Siebel Technical Notes, Siebel Alerts, Siebel CRM Update Guide and Release Notes on My Oracle Support or other publications before transferring them to the z/OS host.Upgrade the target database by performing the following tasks:
Upgrade the repository and import seed data as described in Upgrading the Repository and Importing Seed Data.
If the upgrade contains unacceptable errors, do the following:
Restore the backup of the database that you made previously (see Preparing Developers for the Upgrade).
Correct the errors.
Rerun the Database Configuration Wizard.
Back up the upgraded database repository.
