Upgrade the Siebel Database Schema (upgrep + upgphys)
- Create the staging database by performing the following tasks:
- Generate the upgrade files by performing the following tasks: Note: Edit the generated files as required by Siebel Technical Notes, Alerts, Siebel CRM Update Guide and Release Notes on My Oracle Support, or other publications before transferring them to the z/OS host.
- Upgrade the target database by performing the following tasks:
- Extract the storage control file from the target database using the Database Configuration Wizard as follows: - Specify the following values when prompted to do so: - Extract Options: Extract from Catalog.
- Storage Control File: Specify the name of the storage control file to be extracted. You must specify the name storage_postupg.ctl.
- Make sure you specify values for the target database when prompted for the names of the schema Qualifier, ODBC data source, and database user name and password.
 - The procedure to extract a storage control file using the Extract from catalog option is described in Implementing Siebel Business Applications on DB2 for z/OS. The extracted target database storage control file is used as input to the upgphys upgrade process.
- Upgrade the repository and import seed data. See Upgrading the Repository and Importing Seed Data.
- If the upgrade contains unacceptable errors, do the following: - Restore the backup of the database.
- Correct the errors.
- Rerun the Database Configuration Wizard.
- Back up the upgraded database.
