Approving Point Blocks
After the loyalty manager creates the point block, another manager might have to approve it.
To approve point blocks
- Navigate to the Loyalty Program Administration screen.
- In the Programs list, select the program whose point blocks you want to approve and click its Program Id hyperlink.
- Click the Point Blocks view tab.
- In the Point Blocks list, use a query to find all point blocks with the value Submitted in the Status field.
- To approve a point block, select Approved in the Status field.
