Defining Point Subtypes
The following procedure describes how to define point subtypes.
To define point subtypes
- Navigate to the Loyalty Program Administration screen.
- In the Programs list, select the program that uses the point subtypes you want to define, and click its Program Id hyperlink.
- Click the Point Sub Types view tab, then add a new record to the Point Sub Types list for each point subtype. Complete the necessary fields described in the following table. - Field - Description - Name - Enter a name for the point subtype. - Default - Select the checkbox for one subtype in the list, to indicate that it is the default subtype that is given if no subtype is specified.
