Entering Loyalty Terms for Auto-Creation of Point Blocks
Use the Loyalty Terms view to specify several features of auto-creation of points for each partner, including which pricing rule is used for this partner.
To enter loyalty terms for auto-creation of point blocks for a partner
- Navigate to the Partners screen, then the Partner List view.
- Drill down on the Partner Name of the appropriate partner company.
- In the Loyalty Terms list, add a new record if required and complete the necessary fields. Some fields are described in the following table. - Field - Description - Pricing Rule - Select the pricing rule used to price this point block. - Reorder Limit - Enter the number of points remaining in the existing block for a a new block to be auto-created. For example, if you enter 10,000, then a new block is auto-created when the existing block for this partner has less than or equal to 10,000 points remaining. - Minimum Order Quantity - Enter the number of points in the auto-created point block.
