Options for Configuring How Frequently Siebel Remote Uses TrickleSync
Siebel Remote describes options you can specify to configure how frequently Siebel Remote uses TrickleSync.
| Option | Description | Retry |
System boot up |
Do the next synchronization after the computer starts and is operational. |
If a network connection is not available, then try again the next time the computer reboots. |
Mobile Client Startup |
Synchronize after the remote client starts. |
If a network connection is not available, try again the next time the remote client starts. |
Minutes |
Synchronize at the interval in minutes that the Minutes picklist specifies. You can configure a TrickleSync synchronization to occur as frequently as every 10 minutes. |
Not applicable. |
Hourly |
Synchronize every hour at the minute after the hour that the Hourly At field specifies. For example, if the Hourly At field is 25, then Siebel Remote synchronizes at a 1 to 25 ratio, a 2 to 25 ratio, and so on. |
If the computer is not operational at the specified time, then Siebel Remote synchronizes at the earliest time when the computer is operational. |
Daily |
Synchronize every day at the time that the Daily At field specifies. For example, to specify synchronization to occur every day at 10:00 in the evening, you can enter 10:00 PM. It is not necessary to enter periods in PM. |
Weekly |
Synchronize every week on the day that you choose in the Weekly On picklist, and at the time that you enter in the Weekly At field. |
