Preparing Criteria Values and Criteria Skills for an MLOV
In this topic, you prepare criteria values and criteria skills for an MLOV.
To prepare policy conditions and action arguments for an MLOV
  1. Complete Preparing Policy Conditions and Action Arguments for an MLOV with the following modifications:
    1. In Step 1 in Preparing Policy Conditions and Action Arguments for an MLOV, display the Workflow Policy Column and Assignment Attribute object types.
    2. In Step 6 in Preparing Policy Conditions and Action Arguments for an MLOV, identify the fields that reference the following object types:
      • Criteria Values
      • Criteria Skills
      • Workload Rules
  2. Set the criteria for each field that references criteria values and criteria skills:
    1. In the Object Explorer, click Assignment Attribute.
    2. In the Assignment Attributes list, locate the assignment attribute that must work with an MLOV field.
    3. Set properties of the assignment attribute using values from the following table.
      Property Value
      Translate
      Contains a check mark.
      Translate Pick Field
      Choose the field that stores the language-independent code. The Name field typically stores the language-independent code.
    4. Repeat Step 2 for each field until you configured all criteria.
  3. Set the workload rules for each field you identified in Step b:
    1. Create a new list to display language-independent code values.
    2. Create a new applet to display language-independent code values.
    3. Configure the workflow policy column to use the new list and applet.
    4. Choose the values for predefined records.
    Work you perform in this step is similar to work you perform to configure a workflow policy. For more information, see Preparing Policy Conditions and Action Arguments for an MLOV.
  4. Test and then deliver your Workspace.
    For more information, see Using Siebel Tools.
