Accessibility for Siebel Management Console
Siebel Management Console supports enhanced accessibility.
Siebel Management Console Keyboard Shortcuts
The keyboard shortcuts (hotkeys) for regions within the Siebel Management Console user interface are shown in the following table.
| Region | Keyboard Shortcut |
Navigation menu |
Alt+N |
Toolbar or view overview level |
Alt+O |
List view |
Alt+L |
Details or form view |
Alt+C |
Navigation bar (breadcrumb) |
Alt+M |
Global search |
Alt+G |
Copyright |
Alt+R |
A user can also use various keyboard keys to move the focus through the user interface controls in Siebel Management Console, and to execute functions, as appropriate for the control that has the focus. Try these keys in various contexts to fully understand their actions. The tables that follow provide details about keyboard navigation options in some of these contexts.
For information about accessibility for Siebel CRM applications, see Siebel Fundamentals Guide.
Navigation Menu Keyboard Shortcuts
In the Navigation menu (accessible using Alt+N), the following keyboard shortcuts are available, as shown in the following table.
| Keyboard Shortcut | Action |
Forward Arrow |
When focus is on a closed node, opens the node; focus does not move. When focus is on an open node, moves focus to the first child node. When focus is on an end node, does nothing. |
Back Arrow |
When focus is on an open node, closes the node. When focus is on a child node that is also either an end node or a closed node, moves focus to its parent node. When focus is on a root node that is also either an end node or a closed node, does nothing. |
Down Arrow |
Moves focus to the next node that is focusable without opening or closing a node. |
Up Arrow |
Moves focus to the previous node that is focusable without opening or closing a node. |
End |
Moves focus to the last node in the tree that is focusable without opening a node. |
Home |
Moves focus to the first node in the tree without opening or closing a node. |
Enter |
Selects the node. When focus is on a parent node, opens or closes the node. |
View Overview Keyboard Shortcuts
In the toolbar or view overview section (accessible using Alt+O), the following keyboard shortcuts are available, as shown in the following table.
Forward Arrow Back Arrow |
Moves focus between the view title and action buttons. |
Enter or Space |
Selects the action button with the focus. |
List View Keyboard Shortcuts
In a list view (accessible using Alt+L), the following keyboard shortcuts are available, as shown in the following table.
Nonquery mode |
Forward Arrow |
Moves focus to the cell after the current one (if it exists). |
Back Arrow |
Moves focus to the cell before the current one (if it exists). |
Down Arrow |
Moves focus to cell below the current one (if it exists). |
Up Arrow |
Moves focus to cell above the current one (if it exists). |
Page Down |
Views the next page (if it exists) and moves focus to form title. |
Page Up |
Views the previous page (if it exists) and moves focus to form title. |
End |
Views the last page (if not on last page) and moves focus to form title. |
Home |
View the first page (if not on first page) and moves focus to form title. |
Enter |
When focus is on the header, sorts by the column and moves focus to form title. |
Tab / Shift+Tab |
Moves focus to page status and other areas. |
Query mode |
Tab |
Moves focus to next focusable control. |
Shift+Tab |
Moves focus to previous focusable control. |
Enter |
When focus is on a query operator, opens the dropdown list. When focus is in a dropdown list, selects the item and moves focus back to query operator. When focus is on input, executes the query. |
Escape |
When focus is on query option dropdown list, closes it. |
Down Arrow |
When focus is in dropdown list, moves focus to next item. |
Up Arrow |
When focus is in dropdown list, moves focus to previous item. |
Page Down |
View next page (if it exists) and moves focus to form title. |
Page Up |
View previous page (if it exists) and moves focus to form title. |
End |
When focus is in dropdown list, moves focus to the last item. |
Home |
When focus is in dropdown list, moves focus to the first item. |
Form View Keyboard Shortcuts
In a details or form view (accessible using Alt+C), the following keyboard shortcuts are available, as shown in the following table.
Tab |
Moves focus to next item (session, control, error message, buttons, page navigation tabs). |
Shift+Tab |
Moves focus to previous item (session, control, error message, buttons, page navigation tabs). |
Forward Arrow or Back Arrow |
When focused on page navigation tabs, moves focus to the next or previous page. When focus is on a radio button, selects the next or previous button. When focus is on a list-box, selects the option. |
Space or Enter |
When focus is on section header (toggle), expands or collapses the section. When focus is on buttons (Add, Clone, Delete, Previous, Next, Submit, Cancel, Advanced), activates the button. When focus is on a checkbox, checks or unchecks the box. When focus is on a list-box, activates the dropdown list or confirms selected option. |
Navigation Bar (Breadcrumb) Keyboard Shortcuts
In the breadcrumb or navigation bar (accessible using Alt+M), which is found in the Configuration screen, the following keyboard shortcuts are available, as shown in the following table.
Forward Arrow |
When focus is in breadcrumb bar, moves focus to the next item, wrapping from the last to the first if necessary. When focus is in a dropdown menu and on a menu item that has a submenu, moves focus to its first item. When focus is in a dropdown menu and on a menu item that does not have a submenu, moves focus to the next item in the breadcrumb bar. |
Back Arrow |
When focus is in the breadcrumb bar, moves focus to the previous item, wrapping from the last to the first if necessary. When focus is in a submenu of an item in a dropdown menu, closes the submenu and returns focus to the parent menu item. When focus is in a submenu of a breadcrumb item, moves focus to the previous item in the breadcrumb bar. |
Down Arrow |
When focus is in the breadcrumb bar, moves focus to the first item in the dropdown menu. When focus is in a dropdown menu, moves focus to the next item, wrapping from the last to the first if necessary. |
Up Arrow |
When focus is in the breadcrumb bar, moves focus to the last item in the dropdown menu. When focus is in a dropdown menu, moves focus to the previous item, wrapping from the first to the first if necessary. |
Space or Enter |
When focus is in the breadcrumb bar, moves focus to the corresponding configuration view. |
Tab or Shift+Tab |
Moves focus to other elements of the page. |
Global Search Keyboard Shortcuts
In the global search (accessible using Alt+G), the following keyboard shortcuts are available, as shown in the following table.
Down Arrow |
When dropdown list is opened and focus is in input, moves focus to the first item in dropdown list. When dropdown list is opened and focus is inside dropdown list, moves focus to next item. |
Up Arrow |
When dropdown list is opened and focus is inside dropdown list, moves focus to previous item. |
End |
When dropdown list is opened and focus is inside dropdown list, moves focus to the last item. |
Home |
When dropdown list is opened and focus is inside dropdown list, moves focus to the first item. |
Enter or Space |
When dropdown list is opened and focus is inside dropdown list, navigates to the focused item. |
Escape |
When dropdown list is opened and focus is inside dropdown list, closes the dropdown list and moves focus to input. |
Related Topics
Starting the Siebel Management Console
Overview of Siebel Management Console
Supported Activities in Siebel Management Console
