Example of a Siebel Development Environment Upgrade Flow
This topic presents the flow of steps in part of a typical development environment upgrade. The steps are extracted from an actual driver file. To perform an upgrade, the Upgrade Wizard reads the steps in a driver file and performs the commands the steps contain. The driver file type used in this example is as follows:
  • Upgrade: Siebel Industry Application (SIA) 8.0 to Siebel SIA 8.1
  • Environment: Development
  • Upgrade mode: upgrep
  • Database: Oracle Database
  • Multilingual: No
The following table lists the steps in the driver file. The Script or Input File column in the following table lists the SQL file or input file that is executed in each step. The Comment column provides a brief explanation of what the SQL file or input file does. The SQL files used for an upgrade and the contents of the SQL files vary depending on the upgrade mode and database.
Step
Description
Determine collation sequence of database.
Not applicable
Determines database sort order.
Verify repository name
rename_existing_repositories.sql
Renames Siebel Repository to Prior Customer Repository.
Remove interface tables
dropif-db.sql
Removes all Siebel Enterprise Integration Manager tables.
Remove database triggers
trigdrop-db.sql
Removes all dynamically created triggers.
Remove database-level functions and procedures
drop_db_func_proc.sql
Removes the exchange rate function: exrate.
Prepare for table creation
pret.sql
Removes specified tables. Performs DDL operations such as adding columns to tables. Performs DML operations such as revising date formats.
Create temporary tables for SIA
ddlimp utility
ddl_temp_sia.ctl as input
The input file specifies the structure of the tables to be created or updated. These tables are used to perform data migration and other DML changes.
Prepare for table creation for SIA
pret_sia.sql
Drops specified tables. Performs DDL operations such as adding columns to tables. Performs DML operations such as revising date formats.
Create and update tables
ddlimp utility
ddl.ctl as input
The ddl.ctl file specifies the structure of tables to be created or updated.
Create temporary tables for stored procedures
ddlimp utility
ddlsptbl.ctl as input
The input file specifies the structure of temporary tables to be created or updated.
Household data migration for FINS
Household_Mig_Fins.sql
Creates and populates specified temporary tables. Then migrates data to them and performs DML operations. Migrates data back to primary tables. Drops temporary tables.
Prepare for index creation
preschm.sql
Performs DML operations. Moves data between tables. Changes data in existing fields based on specified conditions.
Prepare for index creation for SEA
preschm_sea.sql
Same as preschm.sql.
Prepare for index creation for SIA
preschm_sia.sql
Create indexes
ddlimp utility
ddl.ctl as input
The input file specifies the structure of indexes to be created.
Delete old license key
delappkey.sql
Deletes the Siebel license key from S_APP_KEY.
Preparation of prior customer repository
SWTClob.jar
The SWT to OD Conversion Utility converts Siebel Web Templates to an Object Definition Layout. Converted Web templates are stored in the database.
Import seed data
dataimp utility
seedupg0.inp as input
seedupg1.inp as input
seedupg_locale.inp as input
Prior to importing seed data, dataimp deletes existing seed data.
The seedupg* files contain filters that dataimp uses to prevent deleting seed data that you have modified or seed data meeting specified criteria.
Unmodified seed data has a last update date (LAST_UPD) of 1980-01-01. Dataimp does not delete records where LAST_UPD is later than this date.
Upgrade data after seed data import
upg_data_afterseed.sql
For customers who have not converted to UTC time, sets the UTC value in S_SYS_PREF to False. For customers who have converted to UTC time, the script takes no action.
Upgrade data after seed data import SIA
upg_data_afterseed_sia.sql
None.
Set system preference for codepage for DB
set_codepage.sql
Sets the database codepage in the S_SYS_PREF.
Set system preference for Unicode codepage for DB
set_unicode.sql
Sets the Unicode codepage to UTF-8 in S_SYS_PREF.
Update version component information
upd_upgcomp.sql
Updates the S_UPG_COMP table with the product release level. The S_UPG_COMP table stores version information for application executable programs.
Run Oracle-specific DDL commands
ddlora.sql
Creates Oracle-specific DDL information, such as default storage parameters for docking objects, repository objects, and seed objects.
Import common ancestor repository
repimexp utility
Standard Siebel Repository as input
Imports the Standard Siebel Repository into S_REPOSITORY. For example, if you are upgrading from Siebel 8.1.x, then this command imports the standard Siebel 8.1.x repository.
Remove EIM columns and indexes
rmv_anc_eim_proc_col_ind.sql
Removes Siebel Enterprise Integration Manager processing columns and indexes from the Prior Customer Repository and the common ancestor repository (Standard Siebel Repository). This prevents the repository merge from preserving Siebel Enterprise Integration Manager columns incorrectly.
The merge will preserve only those Siebel Enterprise Integration Manager columns shipped with the new release.
Update Siebel database version
update_ver.sql
seeduver.sql
The update_ver.sql script creates a temporary table, S_APP_VER_TEMP, which contains new version information for the database schema. The seeduver.sql script updates S_APP_VER with this information.
Import New Customer Repository
repimexp utility
Imports New Customer Repository
Imports the New Customer Repository into S_REPOSITORY.
Revises schema version information in S_APP_VER.
Encryption Upgrade
EncryptionUpgrade.jar
Siebel Business Applications allow customers to encrypt sensitive information stored in the Siebel database, for example, credit card numbers, Social Security numbers, birth dates. This information cannot be viewed without access to Siebel Business Applications.
Sensitivedata can be encrypted by using AES256 (Advanced Encryption Standard). This utility identifies the prior encryption types and upgrades their data to the AES.
This utility updates the logical layer of data for columns which are candidates for encryption.
Restore database version
restore_ver.sql
Uses S_APP_VER_TEMP to update the schema version information in S_APP_VER. Drops S_APP_VER_TEMP.
Upgrade repository data SIA
repos_upgrade_sia.sql
None.
repos_upgrade.sql
Makes specific repository-related changes to repository records and to other tables.
Set repository workflow domains to MLOV
set_multilingual.sql
None.
Install SQL packages
seeduver.sql
Verifies that versions are set correctly in S_APP_VER.
ifstrg.sql
Sets storage parameters for Siebel Enterprise Integration Manager tables.
ifindxstrg.sql
Sets storage parameters for Siebel Enterprise Integration Manager table indexes.
pkgseq.sql
Adds a suffix to row IDs in the S_SEQUENCE table. Ensures that row IDs are unique.
pkgldel.sql
Defines s_txn_log_del_proc. Procedure periodically deletes transactions from S_DOCK_TXN_LOG. Also deletes rows from S_DOCK_TXN SET. Prevents need for large rollback segment.
trgreset.sql
Ensures that denormalized rows in S_TERR have correct values.
ddlseq.sql
Sets sequence numbers for specified tables.
pkgvis.sql
Creates function that modifies how Oracle optimizer does visibility check.
delete_dock_rules.sql
Deletes Prior Customer Repository routing rules from S_DOC_VIS_RULE that meet specified conditions. Attempts to preserve rules added using Docking Wizard.
Create database-level functions and procedures
db_func_proc.sql
Creates or replaces the currency exchange rate function: exrate.
Set primary children in data tables
gen_primary1.sql
Sets primary child for S_DOC_QUOTE.
gen_primary2.sql
None.
gen_primary3.sql
Sets primary child for S_LOY_PROMO.
gen_primary4.sql
None.
Fix column alignment for custom objects
AlignApplet.jar
Applet alignments are executed based on the data type of the field. The following alignments are executed across the entire Repository for a similar look and feel for fields:
  • Consistent Left
  • Right
  • Center
Related Topics
About the Siebel Database Configuration Wizard Utilities
About the Siebel Upgrade Wizard and Driver Files
