Migrating Configuration Data and Incremental Changes
When migrating configuration data (such as LOVs, runtime events, and data mapper) and incremental changes, note the following:
LOVs are versioned and may change from one incremental migration to the next.
Performing a full migration creates a single instance of all repository objects and LOVs with version 0.
During incremental migrations, new and/or modified LOVs from the DR are created in the RR with new version numbers.
To seed a new Target environment with all the LOVs and repository objects, the first migration that you perform must always be a full migration.
Note: After a flatten Workspace operation, the next migration must always be a full migration. For more information about flattening Workspaces, see Using Siebel Tools. -
Since LOV is Workspace-enabled, use the Application Workspace Data Service and Incremental Application Workspace Data Service to migrate LOV data including incremental changes.
For all other configuration data (bar incremental changes), use the Application Deployment Manager Projects to migrate data. Migrating incremental changes is not supported here.
For example, to perform a full migration of LOVs using Siebel Migration Application, select the following resource options:
Runtime Repository Data Service
For example, to perform an incremental migration of LOVs using Siebel Migration Application, select the following resource options:
Incremental Runtime Repository Data Service
