The Solution business component has the following Search Specification property: [Solution Item=‘Y’]. For imported records of this type to be visible following an import process, you must import data from the EIM_SOLUTION interface table to the S_RESITEM base table with the value in the SOLUTION_ITEM_FLG column set to ‘Y.’
When importing into the S_RESITEM base table, you need to include the following columns in the ONLY BASE COLUMNS parameter in the EIM configuration file:
FILE_NAME
FILE_EXT
FILE_SRC_TYPE
If these columns are not included in the ONLY BASE COLUMNS parameter, a low-level error will be generated.
Another requirement is that the Internal Publish flag (INTR_PUBLISH_FLG) must be set in the parent record for imports to be visible in the Solution/Resolution Documents view.
