Each responsibility has a Read Only View flag. Set this flag to True to prevent a user from creating data in a view or modifying existing data in a view. To make sure that a user cannot create or modify data in a view, you must select this flag for all responsibilities associated with the user that allow access to the view.
Note: Responsibilities and their relationship to Views can be Workspace enabled in your
development environment. If they have been Workspace enabled in your development environment and
you are working in that environment, then you can only modify them in an editable Workspace. You
do not need an editable Workspace to create and edit Responsibilities and their relationship to
Views in your Production environment.
The Read Only View flag appears in the following locations:
Read Only View flag in Views list under Site Map, Administration - Application, Responsibilities, and then Responsibilities.
Read Only View flag in Responsibilities list under Site Map, Administration - Application, Views, and then Responsibilities.
