In this guide, the term standards-based Web SSO refers to Web SSO systems that support the LDAP standards described in this topic. This topic outlines the requirements for integrating Siebel CRM with a standards-based Web SSO system.
To integrate a standards-based Web SSO authentication system with Siebel Business Applications, the following are the minimum requirements that must be met:
  • The Web SSO authentication system can send the identity of each Siebel user to be authenticated in an HTTP header variable using HTTP1.1 standard W3C HTTP 1.1 RFC-2616+.
    In a standards-based Web SSO implementation, the Siebel Application Interface derives the user’s user name from the HTTP request header variable. The recommended method is to use a header variable populated with an attribute value that is stored in the directory.
  • Siebel Web Single Sign-On is configured for the Siebel Application Interface.
  • The Siebel LDAP security adapter is implemented to provide authentication functionality.
  • The Web SSO authentication system uses a static trust token in the HTTP header.
  • The Web SSO authentication system supports the following:
    • LDAP 3.0 standard based on compliance with IETF LDAP RFC 2256 and later
    • IEFT Password Policy for LDAP Directories (09)
  • In Siebel Application Interface configuration, the fully qualified domain name and the port number for the application interface host are specified. For additional information, see Siebel System Administration Guide.
