Installing Siebel Intelligent Data Archival
This release delivers both Siebel application updates and an external microservice deployment package to enable the archival framework.
Nature of Changes
| Category | Description |
| Binary Changes | Core Siebel binaries have been enhanced to support archival
orchestration via new Archival Administration views. New
siebel-data-archival.zip package containing
| Seed Data Changes | New seed data entries are delivered to enable rule-based archival configuration and monitoring within Siebel. |
| Repository (NEO) Changes | Repository changes under the NEO model include new metadata objects that support rule management, integration, and logging |
| Schema Changes | Database schema changes introduced as part of post-install setup. |
These changes establish the Siebel-side framework required for integration with the external Helidon based Data Archival Microservices.
Prerequisites
Before installation and configuration:
Verify Siebel REST API endpoints are configured and functional.
Install Java21 on the target machine for running the Helidon microservice.
Ensure secure network communication between the Siebel server and the Helidon host.
PostInstall Database Setup
After applying the latest Siebel patch:
Run the Post Install DB Setup utility included in the update package.
This step introduces the required schema objects (tables, indexes, and sequences) for archival rule management and logging.
Steps for Target DB Setup
- Unzip siebel-data-archival.zip from
<Siebel Build>\ses\siebsrvr\BIN\siebel-data-archival.zip. - ArchivalDBSetup.jar is packaged inside siebel-data-archival.zip. Make sure ArchivalDBSetup.jar is present in the same folder as siebel-data-archival.jar .
- ojdbc11-23.6.0.24.10.jar is packaged as part of siebel-data-archival.zip under \libs. Provide the FS path for ojdbc11-23.6.0.24.10.jar in the following command after unzipping it.
- Provide the Target DB details using command line arguments.
- It should connect to the DB and create tables and sequences by executing the following command.
Windows:
Command:
java -cp "<fs>\ArchivalDBSetup.jar;<fs>\libs\ojdbc11-23.6.0.24.10.jar"
com.siebel.siebarchivaldbsetup.ArchivalDBSetup -h <server> -o <port> -s
<instance> -u <tableowner> -p <tableowner_password> Example : java -cp
"C:\siebel-data-archival\target\ArchivalDBSetup.jar;C:\siebel-data-archival\target\libs\ojdbc11-23.6.0.24.10.jar"
phoenix248484.appsdev.fusionappsdphx1.oraclevcn.com -o 1551 -s qa484 -u ORA484130 -p ORA484130
Linux:
Command:
java -cp "<fs>/ArchivalDBSetup.jar:<fs>/libs/ojdbc11-23.6.0.24.10.jar"
"/scratch/home/sblqa1/DA/ArchivalDBSetup.jar:/scratch/home/sblqa1/DA/libs
/ojdbc11-23.6.0.24.10.jar" com.siebel.siebarchivaldbsetup.ArchivalDBSetup -h
