3.16.186 32510 - CMOS battery voltage low
- Alarm Group:
- PLAT
- Description:
- The presence of this alarm indicates the CMOS battery voltage has been detected to be below the expected value. This alarm is an early warning indicator of CMOS battery end-of-life failure, which causes problems if the server is powered off.
- Severity:
- Minor
- Instance:
- May include AlarmLocation, AlarmId, AlarmState, AlarmSeverity, and bindVarNamesValueStr
- HA Score:
- Normal
- Auto Clear Seconds:
- 0 (zero)
- OID:
- tpdCMOSBatteryVoltageLow
- Alarm ID:
- TKSPLATMI11
Recovery:
- It is recommended to contact My Oracle Support.
