6.3.1.3 Exadataメトリックを使用したExadataスマート・フラッシュ・キャッシュの監視
Exadataスマート・フラッシュ・キャッシュに関連するExadataメトリックは、Exadataストレージ・サーバーの、objectType=FLASHCACHEであるMETRICCURRENT、METRICDEFINITIONおよびMETRICHISTORYオブジェクトで識別されます。
例6-1 フラッシュ・キャッシュのメトリック定義の表示
この例は、Oracle Exadata System Softwareで使用可能なフラッシュ・キャッシュのメトリック定義を表示する方法を示しています。
CellCLI> LIST METRICDEFINITION ATTRIBUTES NAME,DESCRIPTION WHERE OBJECTTYPE = FLASHCACHE
         FC_BYKEEP_DIRTY                         "Number of megabytes unflushed for keep objects on FlashCache"
         FC_BYKEEP_OLTP                          "Number of megabytes for OLTP keep objects in flash cache"
         FC_BYKEEP_OVERWR                        "Number of megabytes pushed out of the FlashCache because of space limit for keep objects"
         FC_BYKEEP_OVERWR_SEC                    "Number of megabytes per second pushed out of the FlashCache because of space limit for keep objects"
         FC_BYKEEP_USED                          "Number of megabytes used for keep objects on FlashCache"
         FC_BY_ALLOCATED                         "Number of megabytes allocated in flash cache"
         FC_BY_ALLOCATED_DIRTY                   "Number of megabytes allocated for unflushed data in flash cache"
         FC_BY_ALLOCATED_OLTP                    "Number of megabytes allocated for OLTP data in flash cache"
         FC_BY_DIRTY                             "Number of unflushed megabytes in FlashCache"
         FC_BY_STALE_DIRTY                       "Number of unflushed megabytes in FlashCache which cannot be flushed because cached disks are not accessible"
         FC_BY_USED                              "Number of megabytes used on FlashCache"
         FC_COL_BYKEEP_USED                      "Number of megabytes used for keep objects in Columnar FlashCache"
         FC_COL_BY_USED                          "Number of megabytes used in Columnar FlashCache"
         FC_COL_IO_BYKEEP_R                      "Number of megabytes read from Columnar FlashCache for keep objects"
         FC_COL_IO_BYKEEP_R_SEC                  "Number of megabytes read per second from Columnar FlashCache for keep objects"
         FC_COL_IO_BY_R                          "Number of megabytes that were read from Columnar FlashCache"
         FC_COL_IO_BY_R_ELIGIBLE                 "Number of megabytes eligible to read from Columnar FlashCache"
         FC_COL_IO_BY_R_ELIGIBLE_SEC             "Number of megabytes per second eligible to read from Columnar FlashCache"
         FC_COL_IO_BY_R_SEC                      "Number of megabytes per second that were read from Columnar FlashCache"
         FC_COL_IO_BY_SAVED                      "Number of megabytes saved by reads from Columnar FlashCache"
         FC_COL_IO_BY_SAVED_SEC                  "Number of megabytes saved per second by reads from Columnar FlashCache"
         FC_COL_IO_BY_W_POPULATE                 "Number of megabytes that are population writes into Columnar FlashCache due to read miss"
         FC_COL_IO_BY_W_POPULATE_SEC             "Number of megabytes per second that are population writes into Columnar FlashCache due to read miss"
         FC_COL_IO_RQKEEP_R                      "Number of requests read for keep objects from Columnar FlashCache"
         FC_COL_IO_RQKEEP_R_SEC                  "Number of requests read per second for keep objects from Columnar FlashCache"
         FC_COL_IO_RQ_R                          "Number of requests that were read from Columnar FlashCache"
         FC_COL_IO_RQ_R_ELIGIBLE                 "Number of reads eligible for Columnar FlashCache"
         FC_COL_IO_RQ_R_ELIGIBLE_SEC             "Number of reads per second eligible for Columnar FlashCache"
         FC_COL_IO_RQ_R_SEC                      "Number of requests per second that were read from Columnar FlashCache"
         FC_COL_IO_RQ_W_POPULATE                 "Number of requests that are population writes into Columnar FlashCache due to read miss"
         FC_COL_IO_RQ_W_POPULATE_SEC             "Number of requests per second that are population writes into Columnar FlashCache due to read miss"
         FC_IO_BYKEEP_R                          "Number of megabytes read from FlashCache for keep objects"
         FC_IO_BYKEEP_R_SEC                      "Number of megabytes read per second from FlashCache for keep objects"
         FC_IO_BYKEEP_W                          "Number of megabytes written to FlashCache for keep objects"
         FC_IO_BYKEEP_W_SEC                      "Number of megabytes per second written to FlashCache for keep objects"
         FC_IO_BY_DISK_WRITE                     "Number of megabytes written from flash cache to hard disks"
         FC_IO_BY_DISK_WRITE_SEC                 "Number of megabytes per second written from flash cache to hard disks"
         FC_IO_BY_R                              "Number of megabytes of small reads (OLTP) from flash cache"
         FC_IO_BY_R_ACTIVE_SECONDARY             "Number of megabytes for active secondary reads satisfied from flash cache"
         FC_IO_BY_R_ACTIVE_SECONDARY_MISS        "Number of megabytes for active secondary reads not satisfied from flash cache"
         FC_IO_BY_R_ACTIVE_SECONDARY_MISS_SEC    "Number of megabytes per second for active secondary reads not satisfied from flash cache"
         FC_IO_BY_R_ACTIVE_SECONDARY_SEC         "Number of megabytes per second for active secondary reads satisfied from flash cache"
         FC_IO_BY_R_DISK_WRITER                  "Number of megabytes read from flash cache by disk writer"
         FC_IO_BY_R_DISK_WRITER_SEC              "Number of megabytes per second read from flash cache by disk writer"
         FC_IO_BY_R_DW                           "Number of megabytes of large reads (DW) from flash cache"
         FC_IO_BY_R_DW_SEC                       "Number of megabytes of large reads (DW) per second from flash cache"
         FC_IO_BY_R_MISS                         "Number of megabytes of small reads (OLTP) from disks because some of the requested data was not in flash cache"
         FC_IO_BY_R_MISS_DW                      "Number of megabytes of large reads (DW) from disks because some of the requested data was not in flash cache"
         FC_IO_BY_R_MISS_DW_SEC                  "Number of megabytes of large reads (DW) per second from disks because some of the requested data was not in flash cache"
         FC_IO_BY_R_MISS_SEC                     "Number of megabytes of small reads (OLTP) per second from disks because some of the requested data was not in flash cache"
         FC_IO_BY_R_SEC                          "Number of megabytes of small reads (OLTP) per second from flash cache"
         FC_IO_BY_R_SKIP                         "Number of megabytes read from disks for IO requests that bypass FlashCache"
         FC_IO_BY_R_SKIP_FC_THROTTLE             "Number of megabytes read from disk for IO requests that bypass FlashCache due to heavy load on FlashCache"
         FC_IO_BY_R_SKIP_FC_THROTTLE_SEC         "Number of megabytes read per second from disk for IO requests that bypass FlashCache due to heavy load on FlashCache"
         FC_IO_BY_R_SKIP_LG                      "Number of megabytes read from disk for IO requests that bypass FlashCache due to the large IO size"
         FC_IO_BY_R_SKIP_LG_SEC                  "Number of megabytes read per second from disk for IO requests that bypass FlashCache due to the large IO size"
         FC_IO_BY_R_SKIP_NCMIRROR                "Number of megabytes read from disk for IO requests that bypass FlashCache as the IO is on non-primary, non-active secondary mirror"
         FC_IO_BY_R_SKIP_SEC                     "Number of megabytes read from disks per second for IO requests that bypass FlashCache"
         FC_IO_BY_W                              "Number of megabytes written to FlashCache"
         FC_IO_BY_W_DISK_WRITER                  "Number of megabytes written to hard disks by disk writer"
         FC_IO_BY_W_DISK_WRITER_SEC              "Number of megabytes per second written to hard disks by disk writer"
         FC_IO_BY_W_FIRST                        "Number of megabytes that are first writes into flash cache"
         FC_IO_BY_W_FIRST_SEC                    "Number of megabytes per second that are first writes into flash cache"
         FC_IO_BY_W_LG_CHINT                     "Number of megabytes used for large writes to flash cache due to cache hint"
         FC_IO_BY_W_LG_DTAGE                     "Number of megabytes used for data aging large writes to flash cache"
         FC_IO_BY_W_LG_MRCV                      "Number of megabytes used for media recovery large writes to flash cache"
         FC_IO_BY_W_METADATA                     "Number of megabytes that are flash cache metadata writes"
         FC_IO_BY_W_METADATA_SEC                 "Number of megabytes per second that are flash cache metadata writes"
         FC_IO_BY_W_OVERWRITE                    "Number of megabytes that are overwrites into flash cache"
         FC_IO_BY_W_OVERWRITE_SEC                "Number of megabytes per second that are overwrites into flash cache"
         FC_IO_BY_W_POPULATE                     "Number of megabytes that are population writes into flash cache due to read miss"
         FC_IO_BY_W_POPULATE_SEC                 "Number of megabytes per second that are population writes into flash cache due to read miss"
         FC_IO_BY_W_SEC                          "Number of megabytes per second written to FlashCache"
         FC_IO_BY_W_SKIP                         "Number of megabytes written to disk for IO requests that bypass FlashCache"
         FC_IO_BY_W_SKIP_FC_THROTTLE             "Number of megabytes written to disk for IO requests that bypass FlashCache due to heavy load on FlashCache"
         FC_IO_BY_W_SKIP_FC_THROTTLE_SEC         "Number of megabytes written per second to disk for IO requests that bypass FlashCache due to heavy load on FlashCache"
         FC_IO_BY_W_SKIP_LG                      "Number of megabytes written to disk for IO requests that bypass FlashCache due to the large IO size"
         FC_IO_BY_W_SKIP_LG_SEC                  "Number of megabytes written per second to disk for IO requests that bypass FlashCache due to the large IO size"
         FC_IO_BY_W_SKIP_NCMIRROR                "Number of megabytes written to disk for IO requests that bypass FlashCache as the IO is on non-primary, non-active secondary mirror"
         FC_IO_BY_W_SKIP_SEC                     "Number of megabytes written to disk per second for IO requests that bypass FlashCache"
         FC_IO_ERRS                              "Number of IO errors on FlashCache"
         FC_IO_RQKEEP_R                          "Number of read requests for keep objects from FlashCache"
         FC_IO_RQKEEP_R_MISS                     "Number of read requests for keep objects which did not find all data in FlashCache"
         FC_IO_RQKEEP_R_MISS_SEC                 "Number of read requests per second for keep objects which did not find all data in FlashCache"
         FC_IO_RQKEEP_R_SEC                      "Number of read requests per second for keep objects from FlashCache"
         FC_IO_RQKEEP_R_SKIP                     "Number of read requests for keep objects that bypass FlashCache"
         FC_IO_RQKEEP_R_SKIP_SEC                 "Number of read requests per second for keep objects that bypass FlashCache"
         FC_IO_RQKEEP_W                          "Number of requests for keep objects which resulted in FlashCache being populated with data"
         FC_IO_RQKEEP_W_SEC                      "Number of requests per second for keep objects which resulted in FlashCache being populated with data"
         FC_IO_RQ_DISK_WRITE                     "Number of requests written from flash cache to hard disks"
         FC_IO_RQ_DISK_WRITE_SEC                 "Number of requests per second written from flash cache to hard disks"
         FC_IO_RQ_R                              "Number of small reads (OLTP) satisfied from the flash cache"
         FC_IO_RQ_REPLACEMENT_ATTEMPTED          "Number of requests attempted to find space in the flash cache"
         FC_IO_RQ_REPLACEMENT_DW_FAILED          "Number of times that client DW IOs failed to find a replacement buffer"
         FC_IO_RQ_REPLACEMENT_DW_SUCCEEDED       "Number of times that client DW IOs succeeded in finding a replacement buffer"
         FC_IO_RQ_REPLACEMENT_FAILED             "Number of requests failed to find space in the flash cache"
         FC_IO_RQ_REPLACEMENT_OLTP_FAILED        "Number of times that client OLTP IOs failed to find a replacement buffer"
         FC_IO_RQ_REPLACEMENT_OLTP_SUCCEEDED     "Number of times that client OLTP IOs succeeded in finding a replacement buffer"
         FC_IO_RQ_R_ACTIVE_SECONDARY             "Number of requests for active secondary reads satisfied from flash cache"
         FC_IO_RQ_R_ACTIVE_SECONDARY_MISS        "Number of requests for active secondary reads not satisfied from flash cache"
         FC_IO_RQ_R_ACTIVE_SECONDARY_MISS_SEC    "Number of requests per second for active secondary reads not satisfied from flash cache"
         FC_IO_RQ_R_ACTIVE_SECONDARY_SEC         "Number of requests per second for active secondary reads satisfied from flash cache"
         FC_IO_RQ_R_DISK_WRITER                  "Number of requests read from flash cache by disk writer"
         FC_IO_RQ_R_DISK_WRITER_SEC              "Number of requests per second read from flash cache by disk writer"
         FC_IO_RQ_R_DW                           "Number of large reads (DW) satisfied from the flash cache"
         FC_IO_RQ_R_DW_SEC                       "Number of large reads (DW) per second satisfied from the flash cache"
         FC_IO_RQ_R_MISS                         "Number of small reads (OLTP) that did not find all data in flash cache"
         FC_IO_RQ_R_MISS_DW                      "Number of large reads (DW) that did not find all data in flash cache"
         FC_IO_RQ_R_MISS_DW_SEC                  "Number of large reads (DW) per second that did not find all data in flash cache"
         FC_IO_RQ_R_MISS_SEC                     "Number of small reads (OLTP) per second that did not find all data in flash cache"
         FC_IO_RQ_R_SEC                          "Number of small reads (OLTP) per second satisfied from the flash cache"
         FC_IO_RQ_R_SKIP                         "Number of requests read from disk that bypass FlashCache"
         FC_IO_RQ_R_SKIP_FC_THROTTLE             "Number of requests read from disk that bypass FlashCache due to heavy load on FlashCache"
         FC_IO_RQ_R_SKIP_FC_THROTTLE_SEC         "Number of requests read from disk per second that bypassed FlashCache due to heavy load on FlashCache"
         FC_IO_RQ_R_SKIP_LG                      "Number of requests read from disk that bypass FlashCache due to the large IO size"
         FC_IO_RQ_R_SKIP_LG_SEC                  "Number of requests read from disk per second that bypass FlashCache due to the large IO size"
         FC_IO_RQ_R_SKIP_NCMIRROR                "Number of requests read from disk that bypass FlashCache as the IO is on non-primary, non-active secondary mirror"
         FC_IO_RQ_R_SKIP_SEC                     "Number of requests read from disk per second that bypass FlashCache"
         FC_IO_RQ_W                              "Number of requests which resulted in FlashCache being populated with data"
         FC_IO_RQ_W_DISK_WRITER                  "Number of requests written to hard disks by disk writer"
         FC_IO_RQ_W_DISK_WRITER_SEC              "Number of requests per second written to hard disks by disk writer"
         FC_IO_RQ_W_FIRST                        "Number of requests that are first writes into flash cache"
         FC_IO_RQ_W_FIRST_SEC                    "Number of requests per second that are first writes into flash cache"
         FC_IO_RQ_W_LG_CHINT                     "Number of large writes to flash cache due to cache hint"
         FC_IO_RQ_W_LG_DTAGE                     "Number of data aging large writes to flash cache"
         FC_IO_RQ_W_LG_MRCV                      "Number of media recovery large writes to flash cache"
         FC_IO_RQ_W_METADATA                     "Number of requests that are flash cache metadata writes"
         FC_IO_RQ_W_METADATA_SEC                 "Number of requests per second that are flash cache metadata writes"
         FC_IO_RQ_W_OVERWRITE                    "Number of requests that are overwrites into flash cache"
         FC_IO_RQ_W_OVERWRITE_SEC                "Number of requests per second that are overwrites into flash cache"
         FC_IO_RQ_W_POPULATE                     "Number of requests that are population writes into flash cache due to read miss"
         FC_IO_RQ_W_POPULATE_SEC                 "Number of requests per second that are population writes into flash cache due to read miss"
         FC_IO_RQ_W_SEC                          "Number of requests per second which resulted in FlashCache being populated with data"
         FC_IO_RQ_W_SKIP                         "Number of requests written to disk that bypass FlashCache"
         FC_IO_RQ_W_SKIP_FC_THROTTLE             "Number of requests written to disk that bypass FlashCache due to heavy load on FlashCache"
         FC_IO_RQ_W_SKIP_FC_THROTTLE_SEC         "Number of requests written to disk per second that bypass FlashCache due to heavy load on FlashCache"
         FC_IO_RQ_W_SKIP_LG                      "Number of requests written to disk that bypass FlashCache due to the large IO size"
         FC_IO_RQ_W_SKIP_LG_SEC                  "Number of requests written to disk per second that bypass FlashCache due to the large IO size"
         FC_IO_RQ_W_SKIP_NCMIRROR                "Number of requests written to disk that bypass FlashCache as the IO is on non-primary, non-active secondary mirror"
         FC_IO_RQ_W_SKIP_SEC                     "Number of requests written to disk per second that bypass FlashCache"
次の追加詳細に注意してください。
  • Exadataスマート・フラッシュ・キャッシュの領域は、キャッシュラインと呼ばれるチャンクで内部的に管理されます。FC_BY_ALLOCATEDは、フラッシュ・キャッシュ内のキャッシュラインに割り当てられている領域の量(MB)を表します。値がフラッシュ・キャッシュのサイズに近い場合、フラッシュ・キャッシュは満杯です。
  • FC_BY_USEDは、フラッシュ・キャッシュ内のデータが占有している領域の量(MB)を表します。OLTPなどのワークロードについて、OLTP書込みではキャッシュラインのごく一部しか使用されないため、FC_BY_USED値をFC_BY_ALLOCATEDよりもずっと小さい値にすることができます。OLTPキャッシュラインで使用される合計量は、FC_BY_ALLOCATED_OLTPによって追跡されます。
  • _DWで終わる名前を持つ様々なフラッシュ・キャッシュ・メトリックは、大規模な読取り操作を追跡します。これらの操作は通常、データ・ウェアハウス・ワークロードに関連付けられています。これらの各メトリックには、通常OLTP操作に関連付けられている小規模の読取り操作を追跡する対応するメトリックがあります。合計数を取得するには、大きい読取りメトリック値を対応する小さい読取りメトリック値に追加します。
    たとえば、フラッシュ・キャッシュで対応された読取りの合計数を取得するには、FC_IO_RQ_R_DWをFC_IO_RQ_Rに追加します。
