Suspense Element
Suspense tracks the flow of money as it is received by the carrier and then consumed by one or more Policy level activities. The existence of this element in the transaction configuration will add a Suspense tab on the Activity entry screen. One Suspense item must be selected or entered in this tab. As the Activity processes, the amount of payment is added to the "Attached" amount as long as it does not exceed the full suspense amount. This reduces or clears the amount available for subsequent "attachments". If a Suspense item's amount is not available to attach, an error will be generated.
| Element/Tag | Attributes | Parent Element | Description | Element/Attribute Value |
<Suspense> |
<Transaction> |
Optional: This element adds the Suspense tab to the Activity entry so the user may select or enter a Suspense item to associate with the Activity. This element cannot exist in the same transaction definition as the <MultiSuspense> element. The element's field reference contains the amount that will be attached. |
Values:
OVERRIDABLE |
<Suspense> |
Optional: This attribute defines user capabilities upon generated errors. |
Values:
VALUE |
<Suspense> |
Required: This attribute defines how the invested amount compares to the unattached suspense amount. |
Values:
REQUIRED |
<Suspense> |
Optional: This attribute defines whether suspense must be associated with the activity. |
Values:
AUTOENTRY |
<Suspense> |
Optional: This attribute defines the automatic creation of suspense detail. |
Values:
XML Schema
<Transaction>
<Suspense OVERRIDABLE="[No | Yes | Ignore]" VALUE="[Sufficient | Equals]" REQUIRED="[Yes | No]" AUTOENTRY="[No | Yes]">[field name]</Suspense>
</Transaction>
XML Example
<Transaction>
<Fields>
<Field>
<Name>PaymentAmount</Name>
</Field>
</Fields>
<Suspense OVERRIDABLE="No" AUTOENTRY="No" VALUE="Sufficient">PaymentAmount</Suspense>
</Transaction>
