Assigning a Risk Scoring Matrix to a Project from the EPS Page
You need to assign a risk scoring matrix to a project before it can be used to prioritize risks. Once you assign a scoring matrix to a project, it is available for use from the risk register on the Risks page in the Projects section.
You can assign a risk scoring matrix to a project from multiple locations in the application. Use this method when you are setting up a project or modifying project settings.
To assign a risk scoring matrix to a project from the EPS page:
  1. Click Projects.
  2. On the Projects navigation bar, click EPS.
  3. On the EPS page:
    1. Locate the project you want to associate with a risk scoring matrix.
    2. Double-click in the Risk Scoring Matrix field and click  Select.
    3. In the Select Risk Scoring Matrix dialog box, select a matrix and click Assign.
    4. On the EPS page, click Save.
Tip
Related Topics
About Risk Scoring Matrices
Working with Risk Scoring Matrices
Creating Risk Scoring Matrices
Assigning a Risk Scoring Matrix to a Project from the Enterprise Data Pane
Assigning a Risk Scoring Matrix to a Project from the Portfolios Section
Risk Scoring Matrices Page
Last Published Wednesday, January 7, 2026
