Terminating Document Reviews
You can terminate document reviews that you initiated.
To terminate a document review:
  1. On the  Navigation Menu, expand  Dashboard.
  2. On the Dashboards page, select a dashboard.
  3. On the dashboard, expand the Document Reviews portlet.
  4. In the Document Reviews portlet, click the My Reviews tab.
  5. On the My Reviews tab:
    1. Select the name of the document review you want to terminate.
    2. Click Terminate.
Tip
Configure dashboard content to add a portlet to the dashboard if it is not available.
Related Topics
About Document Reviews
Working With Document Reviews
Reviewing Documents
Creating Document Reviews
Participating in Document Reviews
Document Reviews Portlet of the Dashboards Page
Configuring Dashboard Content
Last Published Wednesday, April 1, 2026
