Assigning Resources to Unstaffed Activities
You can assign resources to activities that currently have no resources.
To assign resources to unstaffed activities:
  1. On the  Navigation Menu, expand  Projects and click Team Usage.
  2. On the Team Usage page:
    1. Click Role.
    2. Expand a project and select a role.
  3. In the Role Activities for Project dialog box, select the Select option next to an assignment and click Assign Resource....
  4. In the Select Resource dialog box:
    1. Select an option on the View Resources By list.
    2. Select a resource.
    3. Click Select.
  5. In the Assignment Settings dialog box:
    1. Select whether to Use the Price per Unit from the resource or assignment.
    2. Select whether to Use the Units Per time and Overtime Factor from resource or assignment.
    3. Click OK.
  6. Click Close.
Tip
  • The list of resources you can select from is determined by your resource access privileges and individual resource's current project association.
  • To review allocation details before assigning, in the Select Resource dialog box, select a resource and click Show Usage "".
  • To save time, you can search for resources who meet specific requirements.
  • You can also assign resources to activities from the Assignments detail window of the Activities page, the Open Requests for Resources portlet of a dashboard, or the Assignments page of the Resources section.
Related Topics
About Team Usage
Customizing Team Usage
Exporting Team Usage Spreadsheets
Sending Email to a Project Manager
Role Activities for Project Dialog Box of the Analysis Page
Assigning Resources to Unstaffed Activities Using Open Requests for Resources Portlet
Last Published Wednesday, April 1, 2026
